Vazduhoplovi
Postovi: 4656
Re: Vazduhoplovi
:losevidim:
Postovi: 49275
Re: Vazduhoplovi
Chemtrails?
Postovi: 49275
Re: Vazduhoplovi
Postovi: 49275
Re: Vazduhoplovi
Postovi: 5297
Re: Vazduhoplovi
BAJKER
Postovi: 6086
Re: Vazduhoplovi
Post od BAJKER »
Ovaj auto sto je parkiran, prilikom poletanja farba mu je ispeskirana za dz :mrgreen:
dragan
Postovi: 9344
Re: Vazduhoplovi
Post od dragan »
:kezo: :kezo: :kezo:
i onda prica o bezbednosti letenja :)
Postovi: 7512
Re: Vazduhoplovi
Al' ga spusti sofer :bravo: :)
Mozda na leto napravim ovakav jedan snimak :djavo:
Re: Vazduhoplovi
Samo nemoj da parkiraš kod ograde. :kezo:
Sent using Tapatalk
Postovi: 23580
Re: Vazduhoplovi
NE secam se da sam tu parkirao auto :kezo:
Postovi: 5297
Re: Vazduhoplovi
IR F100 Crashlanded, no Fatalities
http://avherald.com/h?article=4742ca4c&opt=0
An Iran Aseman Airlines Fokker 100, registration EP-ASZ performing flight EP-853 from Mashad to Zahedan (Iran) with 103 people on board, was on approach to Zahedan when the left main gear did not extend prompting the crew to abort the approach and enter a hold at about 12:00L (07:30Z). Attempts to lower the left main gear via alternate means were without success forcing the crew to perform a partial gear up landing on Zahedan's runway 35 about one hour after aborting the first approach, the aircraft veered left off the runway causing a huge plume of dust rising above the aircraft. The aircraft came to a stop about 1500 meters down the runway left off the runway. 9 occupants received minor injuries, 2 of them were taken to hospital for observation, 7 treated at the airport. The aircraft received substantial damage.
The airport reported the aircraft entered a hold for about one hour after the left main gear did not indicate down and locked. The crew attempted to the extend and lock the gear according to checklists, but all attempts failed. The aircraft burned off fuel while emergency services prepared for the arrival of the aircraft. There were no injuries during the landing, however, during the emergency evacuation 9 injuries occurred as result of people rushing out of the emergency exits. The accident is under investigation.
Video:
http://www.tabnak.ir/fa/news/399484/%D9 ... 8%A7%D9%86
Postovi: 49275
Re: Vazduhoplovi
Postovi: 4656
Re: Vazduhoplovi
"Ako izreknete dovoljno veliku laz i nastavite da je ponavljate, ljudi ce poverovati u nju"......
Covek koji je izrekao ovo, mora da je bio uzor ljudima iz adekvatnih sluzbi koje sada upravljaju Er Srbijom.
Kada se "Lideru u regionu" skine carevo ruho, i pogleda sta stoji iza neverovatnog zatrpavanja bibordima, saopstenjima i friziranim vestima, mogu se videti razne slike koje odslikavaju pravo stanje.
Na ulasku u jednu od poslovnih zgrada, reci koje necete videti kada ulazite u zgrade Etihada.
Samo desetak metara posle ulaza - otpale ploce sa plafona, paucina koju niko nije uklonio zadnjih dvadeset godina, hodnici bez svetla, stari natpisi, i vesele mladjane stevke koje razdragano razmenjuju informacije kako ce od naredne godine leteti na A330 :kuku:
Postovi: 4656
Re: Vazduhoplovi
A evo malo i drugog lidera u regionu - Beogradskog aerodroma.
Kao sto sam pisao pre godinu dana, kada padne jaca kisa, putnici upadaju u kante koje skupljaju vodu.
Taze fotke. Plafon prokisnjava tacno na centralnom delu aerodromske zgrade, iza pasoske a ispred fri sopa, tacno na putu prema gejtovima.
Propustaju i prozori.
Nisam hteo da pravim inspekciju po zgradi, ali i ovo je dovoljno
Postovi: 13474
Re: Vazduhoplovi
Kulturica
