2020 Fiat 500e
Postovi: 48589
Re: 2020 Fiat 500
'France Edition', 500 copies, placed at the heart of the range. € 29,900 hatchback, € 32,900 convertible.
Postovi: 48589
Re: 2020 Fiat 500
Postovi: 48589
Re: 2020 Fiat 500
Fiat Prepping Optional Front-Opening Third Door For 500 EV
https://todaynewspost.com/auto-news/fia ... ctric-car/
With deliveries of the two-door new Fiat 500 EV set to commence next month, it’s now being reported that the Italian carmaker is also planning on revealing another variant of the electric minicar, featuring a small, front-opening door for easier access to the rear seats.
This third door will be placed on the right side of the car, adding about 66 lbs (30 kg) to the vehicle’s total weight, incorporating the B-pillar for added strength.
Sales for this novel three-door variant would commence in early 2021, as per Autonews Europe.
As for what it could be called, people briefed on the plan claim that it could take on the name Trepiuno, or “three plus one”, as a connection to the 2004 concept that had the same name, which eventually morphed into the production Fiat 500 back in 2007.
However, that particular concept could convert to a four-seater from a three-seater, hence the designation. In case of the electric 500, it would refer to it having two doors, a tailgate and this new third door.
Of course, such a setup is not something we haven’t seen before in the industry. Remember the Mazda RX-8 sports car? It too had a third door just like this – as did the first-generation MINI Clubman (current one has four doors), and of course various extended cab pickup trucks. Now, since this third door would be on the right side of the new 500 electric, it means that it would be on the driver’s side in the UK and Ireland.
The model will stand as the third variant of the new 500, after the hatchback and convertible. Full pricing will be announced at a later date.
Postovi: 48589
Re: 2020 Fiat 500
Troje vrata.
Postovi: 48589
Re: 2020 Fiat 500
Postovi: 48589
Re: 2020 Fiat 500
The basic version now: The most basic finish has an electric motor of 70 kW, a maximum power equivalent to 94 hp, which gives a range of 180 km, although the brand claims that it can be extended to 240 km if you only drive in town.
Postovi: 7941
Re: 2020 Fiat 500
Nisam ispratio... Od sad ce prodavati samo elektricnu verziju ili ce biti i klasicne?
motorista
Postovi: 1029
Re: 2020 Fiat 500
Post od motorista »
Tako je najavljeno - samo električni.
... ovo 3+1 mi deluje kao iz očaja.
Postovi: 13547
Re: 2020 Fiat 500
Voleo bi da probam tu elektricnu ficu, verujem da bi mi vise legla nego benzinac. Polozaj rucice menjaca mi uopste nije odgovarao, previsoko je postavljena.
Postovi: 48589
Re: 2020 Fiat 500
Postovi: 48589
Re: 2020 Fiat 500
Postovi: 9734
Re: 2020 Fiat 500
sad vec postaje ruznjikav i gubi onaj smek koji je imao, zadnji kraj i nekako ali napred mi se ne svidja uopste, enterijer uzasan. Verzija sa dodatnim vratima kao da je neko kod kuce prepravio brusilicom, bez ikakvog smisla, onako na silu dodato. sve se vise upropascava i onao malo lepih automobila koji su ostali
Postovi: 7941
Re: 2020 Fiat 500
Sa velikim delom cu se sloziti.
Postovi: 48589
Re: 2020 Fiat 500
Postovi: 48589
Re: 2020 Fiat 500
