Vazduhoplovi
Postovi: 5298
Re: Vazduhoplovi
Yeti Airlines, 15.01.2023:
https://www.flightradar24.com/blog/wp-c ... Report.pdf
Piloti su featherovali motore umesto da spuste flaps.
At 10:56:27, the PF disengaged the Autopilot System (AP) at an altitude of 721 feet Above Ground Level (AGL). The PF then called for “FLAPS 30” at 10:56:32, and the PM replied, “Flaps 30 and descending”. The flight data recorder (FDR) data did not record any flap surface movement at that time. Instead, the propeller rotation speed (Np) of both engines decreased © Aircraft Accident Investigation Commission, Nepal 6 simultaneously to less than 25% 1and the torque (Tq) started decreasing to 0%, which is consistent with both propellers going into the feathered condition 2 . On the cockpit voice recorder (CVR) area microphone recording, a single Master Caution chime was recorded at 10:56:36. The flight crew then carried out the “Before Landing Checklist” before starting the left turn onto the base leg. During that time, the power lever angle increased from 41% to 44%. At the point, Np of both propellers were recorded as Non-Computed Data (NCD) in the FDR and the torque (Tq) of both engines were at 0%. When propellers are in feather, they are not producing thrust.
Postovi: 49283
Re: Vazduhoplovi
Postovi: 4657
Re: Vazduhoplovi
^ 100% tacno ^
Postovi: 21169
Re: Vazduhoplovi
Postovi: 4657
Re: Vazduhoplovi
Ocekuje se da ce 2024 god u US nedostajati 24.000 pilota, a vec sada krece nestasica aviomehanicara, kojih za ovu godinu ima 12-18.000 manje nego sto je potrebno (takodje samo US).
Nikad gore!
Re: Vazduhoplovi
Je l primaju i starije početnike ili idu samo mlađi? :mrgreen:
Postovi: 4657
Re: Vazduhoplovi
Mislim da ne biraju.
Sto se tice pilota, kompanija sada obezbedjuje i radnu dozvolu.
Samo evropske dozvole nisu priznate u US, pa mora sve iz pocetka, ko ima zivce.
Postovi: 5298
Re: Vazduhoplovi
Postovi: 4657
Re: Vazduhoplovi
Procitah na hrvatskom zamaero.com da je u BEG pustena u funkciju tzv. "umetnuta" pista.
Srpski cuveni portal T6 nista ne objavljuje o tome sta se desava u nasem dvoristu.
Da ne pominjem da termin "umetnuta pista" ne postoji u strucnoj literaturi, izuzev ako se zagugla pa u pretrazi iskoci ova nasa.
Cekamo prvo sletanje na pogresnu pistu...
Postovi: 5298
Re: Vazduhoplovi
Re: Vazduhoplovi
Eto, umetnuta je u naselje :mrgreen:
Postovi: 21169
Re: Vazduhoplovi
Misliš nelegalni objekti su opkolili pistu.
Postovi: 7838
Re: Vazduhoplovi
Postovi: 22141
Re: Vazduhoplovi
Heinz napisao: 14 Mar 2023, 17:38 Misliš nelegalni objekti su opkolili pistu.
Jednom da ne uspe da uzleti ili ukoči neki veliki kargo, koja bi to kataklizma bila. Ajde ovi sa strane, ali ovi što su u pravcu zabranjene zone direkt, sačuvaj me bože.
Postovi: 7838
Re: Vazduhoplovi
