Alfa Romeo 4C
Postovi: 49331
Alfa Romeo 4C
Par sličica sa Concorso d’Eleganza Villa d’Este. Proizvodnja je zakazana za sledeću godinu, ako ne bude nekih iznenđenja.
http://www.autoedizione.com/alfa-romeo- ... ern-italy/
Postovi: 23580
Re: Alfa Romeo 4C
Meni lici na Lotus Elise
oli
Postovi: 880
Pridružio se: 13 Jan 2012, 19:39
Re: Alfa Romeo 4C
Post od oli »
Bas,bas lep auto
Postovi: 49331
Re: Alfa Romeo 4C
Alfa Romeo to Reveal Production 4C Next Summer
According to autocar.co.uk, the stunning Alfa Romeo 4C will make its public debut in production form much earlier than previously reported. The car was expected to be shown at the 2014 Detroit Auto Show, but apparently the date has been pushed forward a few months, so now it will be revealed at a yet-undecided venue, in the summer of next year.
The car is rumored to weigh 850 kg – the 1.75-liter engine which is expected to power it will be tuned to produce almost 300 hp, so it will make light work of the featherweight coupe. The weight will be kept so low thanks to the extensive use of carbon fiber in its construction. The engine which will be powering the 4C is also at work in the current Giulietta, but in that application it produces 230 hp, enough to make it a viable possibility for a future ‘hot’ Dodge Dart SRT4.
Furthermore, the 159 replacement, the Giulia will apparently be built in two factories around the world, with one of them being possibly located in the US. We will provide you with more information as soon as we have it, as this is a very exciting matter for us as well.
Postovi: 49331
Re: Alfa Romeo 4C
Testiranje prvog prototipa. U proizvodnji će se naći krajem sledeće godine. Trebao bi da bude jedan od prodajnih aduta na američkom tržištu.
Postovi: 49331
Re: Alfa Romeo 4C
AcaKayak
Postovi: 4865
Re: Alfa Romeo 4C
Post od AcaKayak »
Jel ovo u klasi sa SLK i Z4 i tako nesto ili ce da bude dosta skuplje? Mislim, nemam pojma, po motoru mi ne deluje nista bolje od njih, a opet izgleda 10x napucanije...
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: Alfa Romeo 4C
Post od perfiko »
A što je test model ovako izlepljen kad se već zna kako će izgledati?
Re: Alfa Romeo 4C
Videli da tako rade drugi, pa onda i oni :D
Postovi: 49331
Re: Alfa Romeo 4C
AcaKayak napisao:Jel ovo u klasi sa SLK i Z4 i tako nesto ili ce da bude dosta skuplje?
Negde se spominjala okvirna cifra od 40-50.000 €, koja će biti konačna ostaje da se vidi. Što se klase tiče, Alfa (kao i uvek) teži nekoj jedinstvenosti :)
perfiko napisao:A što je test model ovako izlepljen kad se već zna kako će izgledati?
Biće nekih izmena na serijskom modelu.
starac vujadin
Postovi: 11474
Re: Alfa Romeo 4C
Post od starac vujadin »
Nije ista ciljna grupa sa Z4 i SLK... Nažalost, Alfa ima samo čvrst krov i teško da će se mnogo prodavati ako ne bude u ponudi i targa verzija. S druge strane, nije ni hardcore vozački auto kao Lotus Elise na koga najviše liči. Konkurent mu je Audi TTS, Lotus Evora, Porsche Cayman,a oni su nešto komotniji od Alfe...Još jedan problem je što ovakav auto nije u tradiciji Alfe i biće potrebno zadobiti potpuno novu vrstu Alfinih kupaca. Verovatno će bit jako dobar auto za vožnju i s obzirom na planiranu malu težinu verovatno će imati odlične perfomanse, ali mislim da se neće prodavati.
Postovi: 49331
Re: Alfa Romeo 4C
Koliko sam video po američkim forumima, oni jedva čekaju da stigne. Bar tamo prodaja ne bi trebala da bude problem.
starac vujadin
Postovi: 11474
Re: Alfa Romeo 4C
Hajde videćemo...uvek može da se nađe 20 fanatika koji će da štancuju postove i tekstove. Ovakva vrsta kola može da donese pare nekom specijalizovanom proizvođaču kao što je Lotus i to tek posle nekoliko godina kad naprave lepezu modela na istoj platformi, za Alfu je ovo niše produkt. Ako imaju dobar dil sa KTM na čijoj je šasiji napravljen, možda i zarade nešto sitno. AKo naprave targu priča može da se promeni.
Postovi: 25209
Re: Alfa Romeo 4C
starac vujadin napisao:Hajde videćemo...uvek može da se nađe 20 fanatika koji će da štancuju postove i tekstove.
Upravo, entuzijasti nisu oni koji masovno kupuju u slucaju vozila. Ako se fabrika oslanja samo na njih mogu odmah da pisu propalo.
starac vujadin
Postovi: 11474
Re: Alfa Romeo 4C
Pri tome, Alfini entuzijasti kojih doduše ima dosta u odnosu na druge ljubitelje, će trebati da se naviknu na auto koji je po karakteru mnogo bliži Lotusu nego Alfinim core values. Lično mnogo više očekujem od roadstera koji će da prave sa Mazdom.
