2013 Range Rover
Postovi: 25125
2013 Range Rover
We’ve seen plenty of spy photos of the upcoming replacement for the full-sized Range Rover. However, this has to be the least amount of camo the vehicle has been seen in, indicating the launch date is near.
So, this prototype gives us the clearest hint of what the fourth-generation Range Rover will look like once it launches, most likely later this year. Front end styling changes aren’t radical, but the vehicle looks a bit more like the Evoque in the way the contours blend.
The importance of the Range Rover can not be overstated, since the Sport, Discovery and Freelander all benefit from Land Rover’s work with the big RR. So if they developed a new aluminum body or adaptive suspension system for the car, the technology will trickle down to ever SUV they make eventually.
The new Range Rover is indeed believed to benefit from the lightweight aluminum construction that we saw on the from JLR in the full-size XJ luxury limo. The new architecture is also believed to arrive with an increase in legroom in the back.
Expect a full release to come in September at the Paris Motor Show, before the Range Rover goes on sale early next year.
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: 2013 Range Rover
Post od perfiko »
Ma potpuno drugi auto, da ne piše da je Range ne bih ga prepoznao. :mrgreen:
7footer
Postovi: 628
Pridružio se: 19 Jan 2012, 17:53
Garaža: Lexus GS 450h, Chevrolet Trax, Yamaha Stryker
Lokacija: Svet
Post od 7footer »
Тај рад, но неки теренци (Land Cruiser 200, Range Rover, Mercedes G(L)) ни не треба нешто превише да одскачу, јер имају своју традиционалну клијентелу...
Само да му не буде превисока бочна линија, + превише подигнута врата а каросерија под благим углом. И Никако не би ваљало да буде увећани Evoque.
Pozdrav
superboss
Postovi: 3770
Lokacija: Speck in the Sea
Post od superboss »
Svidja mi se sto nastavljaju sa filozofijom F F E :mrgreen:
Postovi: 49222
Postovi: 25125
U sustini od ovog sadasnjeg tesko moze bolje. Sedeo sam i vozao se u nekoliko komada, stvarno vrhunski, jos kada se zna da je na osnovi BMW.
BAJKER
Postovi: 6086
Post od BAJKER »
Da li deli platformu sa BMW X5?
Postovi: 25125
Ne, bice na modifikovanoj JLR platformi.
Texonja
Postovi: 4510
Garaža: X3
Lokacija: Poker table
Post od Texonja »
Izlepili ga trakama, a isti je kao i stari. Ruzan kao da je auto iz 80-tih. Taj njegov zadnji kraj vec deceniju i kusur ne mogu da "progutam".
Jos kad dodam da je na vrhu liste najkvarljivijih automobila u UK, moze da bude i luksuzan i udoban i dobar u offroadu kolikogod hoce... :pop:
Postovi: 49222
Misha
Postovi: 3684
Post od Misha »
Texonja napisao:Izlepili ga trakama, a isti je kao i stari. Ruzan kao da je auto iz 80-tih. Taj njegov zadnji kraj vec deceniju i kusur ne mogu da "progutam".
+1
Postovi: 49222
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
Od kud sad normalna rucica menjaca ? Na ovim iznad ima samo onaj krug sto se vrti,ne znaju ni oni kakav ce da bude...
Postovi: 25125
:bravo:
Range Rover Long Wheelbase
Postovi: 49222
