2023 Dacia Duster III
Postovi: 49344
Postovi: 49344
Re: 2023 Dacia Duster III
Postovi: 49344
Postovi: 49344
Postovi: 49344
It will be presented on November 29 in Portugal!
The brand will also present its expansion plans in new markets such as Australia and New Zealand.
The new Duster will also be available in Latin American markets such as Brazil under the Renault brand and with a 170 horsepower gasoline version exclusive to these markets.
Postovi: 49344
Postovi: 49344
Postovi: 49344
Tce 100 GPL 2WD
Tce 130 2WD et 4WD
Etech Hybrid HEV 140 2WD
Postovi: 14717
Postovi: 14717
Lepo su ga osvežili i modernizovali ali nekako mi na ovom poslednjem videu iznutra deluje još plastičnije i jeftinije nego prethodnici. No ne sumnjam da će se Renault/Dacia razbiti od prodaje sa njim. :)
Postovi: 49344
INCREASED OFF-ROAD CAPABILITIES IN 4X4 VERSION
The new Duster is available with a 4x4 Terrain Control drivetrain that can be driven through 5
driving modes:
- AUTO: the transmission automatically distributes torque between the front and rear axles depending on
grip and speed.
- SNOW: optimizes trajectories on slippery roads thanks to specific settings of the ESC and
traction control.
- MUD/SAND: for traveling on loose surfaces such as muddy or sandy paths.
- OFF-ROAD: offers the best crossing capabilities off-road and on difficult paths. He is
very close in terms of performance to the 4x4 lock mode of the current Duster, but goes further by distributing
automatically and optimally the torque between the front and rear wheels depending on the conditions
adhesion values ​​and vehicle speed.
ECO: allows you to optimize fuel consumption by acting on air conditioning and vehicle performance.
vehicle. It best optimizes the distribution of engine torque between the front and rear axles to limit the
fuel consumption while adapting to road grip conditions.
Off-road-proof ground clearance: 217 mm (measured between the axles) for the 4x4 version, at
best level on the market.
Even more favorable approach and departure angles for overcoming obstacles on 4x4 versions,
up to 31° at the front and 36° at the rear, and a ventral angle of 24°.
A downhill speed control system. This system is particularly useful when driving off-road or
steeply descending. It acts in particular on the brakes to prevent the vehicle from racing away and thus ensure a speed
adapted (according to driver requests) from 0 to 30 km/h. The system works on all gears in the box
of gears, including reverse. The driver no longer has to worry about the accelerator and brake pedals,
only from the steering wheel.
A lot of information particularly useful when driving off-road is displayed on the 10.1 central screen
inches:
- Right/left lateral inclination angle of the vehicle
- Pitch angle to appreciate uphill and downhill slopes
- Torque distribution between the front and rear axles.
For information, the tce 130 is indeed a 48v mHEV, outside Europe DCi 100 and 115 hp will be available.
Postovi: 49344
Renault Duster Coupe/Bigster.
Postovi: 33108
Novi Duster kod nas tek sredinom sledeće godine. Nadaju se da će ga imati za sajam da se izloži jedan primerak ali prodaja tek maj, jun.
Nadaju se početnoj ceni malo ispod 20k plus pdv. Da kažemo 22-23k osnovni model.
Postovi: 14717
Moraju prvo rasprodati lagere starog, naravno. Kad sam kupovao Kadjara Stojanov je imao bar 100 komada Dustera parkiranih i zatiskanih na sve strane. Zamalo da i ja odvezem jednog kući.
Dzona
Postovi: 573
Garaža: VW Arteon 2.0TDi
Post od Dzona »
Čudo, prodaja im baš dobro ide...
Možda su bili spremljeni za neku firmu?
Vidim ih dosta u zapadnoj EU
