Dacia Jogger
Postovi: 49340
Dacia Jogger
Postovi: 49340
Re: Dacia Jogger
Postovi: 49340
Re: Dacia Jogger
Thanks to its 4.5m length and 2.9m wheelbase, the All-New Dacia Jogger offers unrivalled interior space for a family of seven. With three full rows of seating, the All-New Dacia Jogger can easily accommodate seven adults in comfort or, with the split-folding seats arranged into one of more than 60 possible configurations, up to 1,819 litres VDA of cargo space.
The all-new TCe 110 is a 1.0-litre, three-cylinder, direct injection turbocharged petrol engine that boasts 110hp and 200Nm of torque at 2,900rpm. It uses several technical innovations to increase output, improve fuel economy, and reduce emissions. Its aluminium block construction reduces overall weight, while variable valve timing and a variable displacement oil pump help boost performance while reducing fuel consumption. The integrated exhaust manifold, particle filter and central injector help reduce CO2 emissions, while a smooth-shifting, low-friction six-speed manual transmission helps deliver the best possible performance.
The TCe100 Bi-Fuel engine continues Dacia's commitment to offer a full range of bi-fuel petrol/LPG vehicles. When running on LPG, average CO2 emissions for the Dacia Jogger are 10 percent less than for an equivalent petrol engine at 121g/km. In addition, the 40-litre LPG tank and 50-litre petrol tank give the Jogger a combined maximum range of 621 miles with WLTP combined cycle economy of up to 37.1mpg.
By factory-fitting this proven technology to the TCe 100 Bi-Fuel engine, safety and reliability are guaranteed. The duration of the manufacturer's warranty, service intervals, and boot capacity are all identical to the petrol-only version, with the LPG tank fitted beneath the boot floor in place of the spare wheel. On the road, the transition from petrol to LPG is immediate and imperceptible, with the system switching automatically to petrol once the LPG tank is empty.
In 2023, the Jogger will be the first Dacia model to feature hybrid technology, making it the most affordable 7-seater hybrid on the market. The Dacia Jogger Hybrid will feature a 1.6-litre petrol engine, two electric motors, and a multi-mode automatic transmission, combined with a 1.2kWh 230V battery to deliver full electric start, smooth and comfortable electric-only driving, and a choice of driving modes to suit the prevailing conditions. With regenerative braking helping to capture kinetic energy that would otherwise be lost during deceleration, the Dacia Jogger Hybrid will be able to spend 80 percent of its time on city roads in full-electric mode thereby saving up to 40 percent on fuel compared to an equivalent petrol-only model - all without changing the way one drives.
Postovi: 49340
Re: Dacia Jogger
Postovi: 49340
Re: Dacia Jogger
Postovi: 49340
Re: Dacia Jogger
Postovi: 15990
Re: Dacia Jogger
U Srbiji od 13.390,00
Verzija sa 7 sedišta +700,00€
Postovi: 33097
Re: Dacia Jogger
Novi Dacia Jogger je dostupan za naručivanje od 1. decembar 2021., dok u salone stiže u martu 2022. Zasnovan na vrednostima brenda Dacia, novi Jogger najpristupačniji je porodični automobil C-segmenta koji nudi jedinstven odnos cene i kvaliteta u klasi. Cene se kreću od 13.390€.
MOTORI
Novi Dacia Jogger je dostupan sa 1,0-litarskim benzinskim motorom TCe 110 i 6-stepenim ručnim menjačem. Novi motor smanjene mase odlikuju bolje performanse i obrtni moment od 200 Nm.
Jogger je dostupan i sa benzinsko-plinskim motorom ECO-G 100 sa dometom do 1000 km. Servisni intervali, troškovi održavanja i kapacitet prtljažnika su isti kao kod verzije sa benzinskim motorom.
VERZIJA SA PET ILI SEDAM SEDIŠTA
Dacia Jogger je svestrano i modularno vozilo: 2, 3, 4, 5, 6 i 7 sedišta… Verzija sa sedam sedišta može da se konfiguriše na čak 60 različitih načina zahvaljujući pojedinačno uklonjivim sedištima u trećem redu.
https://www.garaza.rs/pocetak-narucivan ... 1638054566
dzonic87
Postovi: 1352
Re: Dacia Jogger
Post od dzonic87 »
Iskonfigurisah za 17100eur :D
Možda ako daju neki popust :mrgreen:
Postovi: 33097
Re: Dacia Jogger
17k je danas jeftin auto. C segment nema ispod 20.
dzonic87
Postovi: 1352
Re: Dacia Jogger
Post od dzonic87 »
Po dimenzijama je nešto kao naslednik lodgy-a.
Pretpostavljam da će biti zahvalno vozilo, hajde da se pojavi pa da vidimo na šta sve to liči uživo
Postovi: 49340
Re: Dacia Jogger
motorista
Postovi: 1049
Re: Dacia Jogger
Post od motorista »
Nekako me podseća na »Matru-Simku Rančo«. I konceptom a i ima mi nečeg dopadljivog u sebi, iako priznajem da mi ukus više naginje klasičnim automobilima.
Postovi: 49340
Re: Dacia Jogger
Moguć prevod titlova na engleski.
Postovi: 49340
Re: Dacia Jogger
