Peugeot 108/Toyota Aygo/Citroen C1
Re: Одг: Peugeot 108
Jos kad bi mi fon otvorio sliku:mrgreen:
Sent from my GT-I9105P using Tapatalk
Re: Peugeot 108
Following yesterday's leak, Peugeot has officially revealed the all-new 108 which for the first time will be offered as a convertible.
The cute French city car aims to be one of the lightest vehicles in this segment with a curb weight starting at just 840 kg (1,851 lbs). It will be sold not only as a three- and five-door hatchback, but also as a cabrio (called 108 TOP!) with a retractable fabric roof similar to the one installed on the Citroën DS3 Cabrio and the more recent third-gen Renault Twingo.
Compared to the outgoing model, the new 108 looks a lot more refined and upmarket thanks to the many styling cues taken from the 308. The vehicle is 3.47m long and 1.62m wide while the fabric roof of the convertible is 76cm long and 80cm wide. Peugeot has equipped the open-air version with an aero-acoustic deflector which automatically deploys in order to diminish cabin turbulence.
Powering the fresh 108 are frugal three-cylinder engines starting out with a 1.0-liter e-VTi delivering 68 bhp (51 kW) to the front wheels through a five-speed manual gearbox. The same engine can be had with a stop/start system to cut down CO2 emissions and also with an automatic transmission. There's also a larger 1.2-liter PureTech VTi outputting 82 bhp (61 kW) and mated to a five-speed manual.
Depending on the selected trim, the 2014 Peugeot 108 will ride on 14-inch alloy wheels shod in 165/65 R14 ultra-low rolling resistance tires or 15-inch rims wrapped around in 165/60 R15 rubbers. All versions come as standard with a hill start assist system along with an indirect tire under-inflation system. Stopping power is provided by 247mm front ventilated discs and 200mm rear drums, as well as systems such as ABS, Emergency Collision Braking System, switchable ESP and Electronic Brake Force Distribution.
At this moment we don't have photos of the interior but according to Peugeot the cabin has a height-adjustable driver's seat, automatic air conditioning and a seven-inch touchscreen display. Also inside is the firm's Open and Go system, six airbags, electric power steering along with the electronic control switch for the retractable soft top.
The 2014 Peugeot 108 will get its first public outing next month at the Geneva Motor Show and is slated to go on sale in the UK on July 1st.
Re: Peugeot 108
Re: Peugeot 108
Trocilindarski motori.
- 1.0l e-VTi 68 KS BVM5, 88g/km de CO2,
- 1.0l VTi 68 KS BVM5, 95g/km de CO2,
- 1.0l VTi 68 KS ETG5, 97g/km de CO2,
- 1.2l VTi 82 KS BVM5, 99g/km de CO2.
Re: Peugeot 108/Toyota Aygo
Re: Peugeot 108/Toyota Aygo/Citroen C1
Citroen C1
Težak 840 kg, dimenzije 3,46 m x 1,62 m x 1,45 m, u verzijama sa troje i petoro vrata: motori e-VTi 68 i VTi 82.
http://www.youtube.com/watch?feature=pl ... PzzGTJ_YeA
Deluje da postaju značajno ozbiljnija vozila.
- trojanac
- Editor in Chief
- Postovi: 33033
- Garaža: KIA Ceed JD 1.4
Ovaj C1 mi se ne dopada od napred. Inače da će biti nešto bolja kola od prethodnika, pa i ne verujem. Samo modernija, ali kad ga kupiš klot, a tako se najviše i prodaju, uvidiš da je to nešto što liči na automobil. Ne znam kakav je up! Njega bi voleo da vidim i provozam.
Tapatalk with Desire 500
Ozbiljniji u smislu da više nije pozicioniran kao jeftino vozilo koje se kolje sa Sparkom nego kao life style koji udara na Adama i Fiat 500. Ako sam u pravu to neminovno povlači sa sobom bolje i kvalitetnije materijale u enterijeru, a to je deo gde je prethodna generacija bila tragična.
- trojanac
- Editor in Chief
- Postovi: 33033
Moguće da žele da ih pozicioniraju tako, mada sumnjam da će uspeti.
- iggyboy
- Postovi: 1134
- Pridružio se: 16 Jul 2012, 14:31
- Garaža: 407 coupe 2.2 petrol
- Lokacija: pozarevac
pezo i nije nesto atraktivan , citroen jeste mnogo atraktivniji , a sto se tice kvaliteta , verovatno je unapredjen ali ne toliko, onda ne bi imali zaradu , ovako kad lupe cenu u startu , mozda i zarade neku paru
▒▓██ P █ A █ R █ T █ I █ Z █ A █ N ██▓▒
■ distinctive vehicle with a chic and stylish design ■ Car connected 4 figures available: ■ 108 5 door and 3 door ■ Top 108! 3-door and 5-door
The front reassured by its robustness and its technological projectors incorporating in their upper part a light guide LED■ Signature light with optical and grille incorporating the new brand PeugeotThe base of the front bumper is standard equipped with two sticks each style incorporating LED daytime running light■ Access Level : black crosses tinted mass■ Active Level: chrome butts■ Levels Allure and Feline : stick with chrome fog lightsengines:■ 1.0VTi 68 95 g ( BVM5 )■ 1.0 VTi 68 88 e- g ( BVM5 )■ 1.2 VTi 82 99 g ( BVM5 )■ 1.0 VTi68 ETG5 97 g ( function creep )New offer more dynamic drive PureTech VTi 82 Stop & Start 1l Vti 68 hp more economicalThe manual gearbox has ETG5 function creep and allows the customer to have an automatic vehicle while guaranteeing an optimum driving pleasureHill Assist is standard on all 108A line highlighted by a dynamic blade wings emerging chromium before and extending at the base of the glazing
A compact version with a length of 3.475 m and a turning circle of 9.6 m (14'' wheels) and 10m (15'' wheels) Easy access through doors that stretch almost a wheel to the other A range of eight exterior colors
opaque ■ White Lipizan ■ Red Scarlett metallized ■ Grey Gallium ■ Grey carlinite ■ Black Caldera ■ Blue Smalt ■ aikinite ■ Red Purple Offer and aluminum alloy rim
The spare wheel such as "cake" and 14'' size: Available in standard or optional depending on trim levels only in Sedan. The provisional tire repair kit, standard on all versions discoverable and sedan is a complete system consisting of a compressor and a sealant cartridge.
The interior elements are broken down as follows: ■ headbands dashboard (right and left of the steering wheel) ■ base shifter ■ front center console ■ ring gear lever knob ■ covers aerator. 3 packs of interiors available at launch * ■ aikinite ■ Porcelain ■ Porcelain aikinite 2 others available from September 2014 ■ Red ■ Red Porcelain Audio Packs 2 levels Audio Packs 3.5'' screen Low radio, optional on the Access level
■ 2 HP ■ Band FM / AM ■ USB port ■ Jack Socket High radio standard on Active level
■ 4 HP and 2 tweeters ■ Bluetooth ■ Steering wheel ■ Band FM / AM ■ USB port ■ Jack Socket ■ Digital Radio (DAB)
The Touch Screen Option:
The touch screen 7 'offers many benefits. Available from Allure level media ■ Bluetooth ■ Streaming audio ■ USB Port ■ Auxiliary
Mirror Screen is to replicate the features and applications compatible smartphone to control directly from the touch screen of the vehicle.The Mirror Screen function starts the engine runningSmartphones running the application " MirrorLink "1 . Download the application corresponding to Smartphone ;2 . Connect the smartphone to the vehicle with the USB plug ;3 . Launch the application on the touch screen ;4 . The application launches automatically on the Smartphone.Iphone working with the application " AppRadio "1 . AppRadio download on the Apple Store;2 . Connect the smartphone to the vehicle via the Jack and USB (USB and Jack Accessoirie cables available ) ;3 . Start " AppinCar " application on the iPhone ;4 . Launch the application on the touch screen.Aid equipment to conductUsing the touch screen:■ Backup Camera■ Vehicle Information■ consumption■ Average speed■ Autonomy■ Time to stop (version VTi68 )The start slope (Hill Assist) automatically maintains the vehicle braked for 2 seconds.
The electronic key is detected approaching the vehicle. The opening and closing take place by simply pressing a dedicated push, and the start pulse on the pulse push Start / Stop. customization 7 themes and customization 3 indoor environments: ■ An offer that allows customers to create their vehicle according to his personality ■ A varied offer but not infinite
■ external Stickers: roof, hood, rear and / or amount of foot B ■ Stickers interior: dashboard ■ Surcoques retro on carpet, surcoques of Plip 108 TOP: 5 themes ■ external Stickers: Lateral amount of foot B, tailgate ■ Stickers interior: dashboard ■ Surcoques retro on carpet, surcoques of Plip 2 Offers Bi-Ton Exclusively for the 3-door hatchback - Active and Allure levels 2 versions ■ Red Purple and Grey Gallium ■ White and Lipizan aikinite
