Škoda Octavia 2013/2017 A7FL
pigeon
Postovi: 558
Pridružio se: 16 Jan 2012, 12:22
Garaža: Škoda Octavia A8 1.4TSI 8AG + Fiat 500
Lokacija: Sombor
Post od pigeon »
Volkswagen sources confirm the all-new Skoda Octavia will be unveiled before the end of this year
The new Skoda Octavia is on its way. Volkswagen revealed at the Moscow Motor Show that the hatchback will be unveiled before the end of the year and hit showrooms early in 2013.
The new Octavia - which was previewed by the five-door Vision D concept at the 2011 Geneva Motor Show - will be built on the same modular platform as the upcoming VW Golf MkVII, which is due to be unveiled at the Paris Motor Show next month.
Thanks to various weight-saving measures, the new chassis should mean the next generation Skoda Octavia is significantly lighter than the model it replaces. This weight saving, combined with an impressive range of diesel and turbo petrol engines from the VW Group stable, should ensure reduced emissions over the outgoing car.
And the new Octavia will be larger than its predecessor, too, in order to provide a clear distinction between it and the new Rapid in the growing Skoda line-up.
Sent from my GT-I9000 using Tapatalk 2
elMaestro
Postovi: 3696
Garaža: C2
Re: Skoda Octavia 2013
Post od elMaestro »
Šta im znači "ovo" na petim vratima? I Rapid i Rapid HB imaju taj neki "urezani" deo čiju poentu nikako ne vidim.
BTW, na prvoj slici je neko pokušao na nacrta A5?
Имам једно потпитање...
Dusan
Postovi: 4285
Lokacija: Wien
Post od Dusan »
+1
Ovaj trougao je stvarno bedan kod stopova i ja se pitam kako nije postojalo neko bolje resenje.
Postovi: 32658
Re: Škoda Octavia 2013
Meni se kod svih Škoda izuzetno sviđaju zadnja svetla, sa tim pozicijama kao položeno slovo U ili V. Jedino mi kod Yetija nije baš lepo, iako je isti fazon, ali ovo ostalo mi se baš sviđa.
Od nove Octavije očekujem mnogo i jedva čekam da vidim šta su spremili. U drugoj temi se vodi diskusija o bratskom Golfu VII, koji će zasigurno biti odličan, ali ja bi nekako radije kupio Octaviu. :)
pigeon
Postovi: 558
Lokacija: Sombor
Post od pigeon »
Mislim da je od trenutno dostupnih slika ova najbliža stvarnosti:
Ovo im je kao slučajno "ispalo" na nekoj prezentaciji... Nazire se novi oblik prednjih i zadnjih svetala i drugačiji zadnji kraj. Sve u svemu obećava.
somi-car
Postovi: 2243
Lokacija: BG
Post od somi-car »
trojanac napisao:Meni se kod svih Škoda izuzetno sviđaju zadnja svetla, sa tim pozicijama kao položeno slovo U ili V. Jedino mi kod Yetija nije baš lepo, iako je isti fazon, ali ovo ostalo mi se baš sviđa.
Mislim da je najveci uspeh oktavije taj sto je brzo, vec sa prvom generacijom izgradila imidz npr kao passat kod wv. Hladan nemacki dizajn, kvalitet i robusnost.
To je najvise pomoglo u prodaji. Sad svaka sledeca generacija samo potvrdjuje kvalitet.
pigeon
Postovi: 558
Lokacija: Sombor
Post od pigeon »
Evo još jedan svež render:
Postovi: 32658
Ovo izgleda dobro. Samo da zadrži peta vrata i može da uđe na spisak želja u narednih 5-10 godina.
pigeon
Postovi: 558
Lokacija: Sombor
Post od pigeon »
Mislim da će fora sa petim vratima ostati jer je zadržana čak i kod Superba, ima je i Rapid pa neće valda da je ukinu na Octaviji.
Postovi: 11029
Mislim da su ono prvo gore slike karoserije Rapida jer su se te slike pojavile malo pre zvanicnih slika Rapida a u kontekstu tog modela. Mada je Rapid Combi odlozen na neko vreme. Ona 'skica' je mnogo dobra, totalno vise nece imati imidz dosadnog i racionalnog ako O3 bude takva.
pigeon
Postovi: 558
Lokacija: Sombor
Post od pigeon »
Uroš S. napisao:Mislim da su ono prvo gore slike karoserije Rapida jer su se te slike pojavile malo pre zvanicnih slika Rapida a u kontekstu tog modela.
Te slike je verovatno moderator dodao. Ja sam prvo otvorio temu bez slika, samo sa tekstom.
ZAXSPEED
Postovi: 216
Pridružio se: 26 Jan 2012, 16:43
Garaža: Passat B7 , Clio IV 1.5 dci
Post od ZAXSPEED »
pigeon napisao:Evo još jedan svež render:
Lepo su izmešali C5 I Isigniu. :navijamo: :navijamo:
Dusan
Postovi: 4285
Lokacija: Wien
Post od Dusan »
:ccc: :uf:
Postovi: 23566
pre ce biti 407 no Insigniu :pardon:
Sve u svemu, siguran sam da nece biti priblizna ovoj sa slike, iako bih to voleo :ludaca:
Ako bude bar priblizna renderu Leon i Golf mogu da pakuju kofere :kezo:
