Putevi budućnosti
Postovi: 49358
Putevi budućnosti
Road-Paver Concept Lays Asphalt Underneath Traffic
http://www.wired.com/autopia/2012/07/road-paver-concept
A recent design school grad has come up with a machine that can pave roads without shutting down lanes or stopping traffic. Too good to be true? Yes. It’s pure, unadulterated vaporware, but the concept is sound even if the chances of production are nil.
Gosha Galitsky, a graduate of the Umeâ Institute of Design in Sweden, conceived a machine that would re-pave the road beneath while vehicles drive up and over. The Dynapac Red Carpet allows cars to pass over, while the machine re-heats and shapes the road surface using microwaves, a process known as Hot-in-Place Recycling. Microwaves heat the upper road layer and the asphalt binding agent, returning the pavement to its original soft state. Rotating brushes scoop the soft asphalt into a tank where it’s mixed with a small amount of fresh binder. The mixture gets paved back onto the road while a set of rollers at the rear compress the new pavement.
Since the Red Carpet moves so slowly, the recycled pavement has time to cool. By the time the machine passes over, the surface is ready to handle traffic. But its berth only allows for cars narrower than 78.7 inches to pass through. Sorry, Hummers.
Galitsky says that road paving is a process that’s overdue for an evolution: “The machines, materials and processes we use to construct and maintain our roads today have not changed significantly since as far as the 1940’s. Since only one basic configuration of paver exists today, road maintenance has to be done using machines which were originally constructed for paving new road surfaces.”
As a bike commuter in New York City, Galitsky has learned to loathe pot holes and love the feel of fresh asphalt, but, he explains, the incentive to keep shoddy roads is high. “Maintaining the streets generally requires shutting traffic down,” he says, “so there is constant pressure on the road working agencies to delay minor repairs until the road condition becomes so bad that the road needs to be torn down completely and paved again using new materials.”
Check out the video below for a full demonstration, along with a dose of Iggy Pop’s “The Passenger.”
Postovi: 25237
Re: Putevi budućnosti
Crnogorska asfalterka. :)
Postovi: 49358
Postovi: 49358
[video]
Ovo bi kod nas bilo pokradeno u roku od odma' ;)
Sent from mTalk
Postovi: 49358
Više je sadašnjost.
Samo mi nije jasan baja koji trči :D
... mada verovatno hoda jer je snimak ubrzan
Sent from mTalk
Scuderia
Postovi: 13495
Post od Scuderia »
:bravo:
Postovi: 49358
[video]
Postovi: 33109
Sjajno.
Postovi: 23580
Kul ideja, samo je pitanje kako gune reaguju po takvoj podlozi u raznoraznim situacijama.
kragujevac
Postovi: 3542
Garaža: Jaguar XF 4.2 V8 (NA)
Lokacija: Minhen/BRD
Post od kragujevac »
Ma čak i da upotrebe ovu vrstu podloge samo u ulicama u gradu gde se vozi 30km/h ili na raznoraznim pešačkim/trim stazama, u fabričkim krugovima, školama i tome slično pa će ušteda biti dovoljna da se isplati.
Jedini problem koji ima ovaj čovek je najverovatnije to što će mu naftni lobi smrsiti konce. Verovatno će da otkupe firmu i da sakriju svu dokumentaciju za sledećih 50 godina.
Ljuba Moljac
Postovi: 49358
Postovi: 49358
Postovi: 49358
