Vazduhoplovi
Postovi: 5298
Re: Vazduhoplovi
Moguce je itekako:
https://en.wikipedia.org/wiki/2002_%C3% ... _collision
TCAS and conflicting orders
The accident raised questions as to how pilots must react when they receive conflicting orders from the TCAS and from air traffic control (ATC). TCAS was a relatively new technology at the time of the accident, having been mandatory[Note 2] in Europe since 2000.[BFU 13] When the TCAS issues a resolution advisory (RA), the pilot flying should respond immediately by direct attention to RA displays and maneuver as indicated, unless doing so would jeopardise the safe operation of the flight, or unless the flight crew can assure separation with the help of definitive visual acquisition of the aircraft causing the RA.[29] In responding to a TCAS RA that directs a deviation from assigned altitude, the flight crew should communicate with ATC as soon as practicable after responding to the RA. When the RA is removed, the flight crew should advise ATC that they are returning to their previously assigned clearance or should acknowledge any amended clearance issued.[29]
While the TCAS is programmed to assume that both crews will promptly follow the system's instructions, the operations manual did not clearly state that TCAS should always take precedence over any ATC commands.[BFU 14] The manual described TCAS as "a backup to the ATC system", which could be wrongly interpreted to mean that ATC instructions have higher priority.[BFU 15] This ambiguity was replicated in the Tu-154 Flight Operations Manual, which contained contradictory sections. On the one hand, chapter 8.18.3.4 emphasised the role of the ATC and describes the TCAS as an "additional aid",[BFU 16] while chapter 8.18.3.2 forbade manoeuvers contrary to the TCAS.[BFU 17] The BFU recommended that this ambiguity should be resolved in favor of obeying TCAS advisories even when these were in conflict with ATC instructions.[BFU 18]
Postovi: 5298
Re: Vazduhoplovi
snork napisao: 07 Nov 2018, 06:18 U prošlosti je bilo više takvih nesreća. Kad je blizu aerodroma i oba sleću / poleću, donekle mogu da razumem da je lako došlo do greške, ali na velikoj visini je totalno bizarno. Kao npr. kod Zagreba 1976, kad su se sudarili Inex Adria DC-9 i British Airways-ov Hawker Siddeley Trident: https://en.wikipedia.org/wiki/1976_Zagr ... _collision
Postovi: 4657
Re: Vazduhoplovi
passenger napisao: 07 Nov 2018, 07:42 Sad svi imaju TCAS. Zar sistem ne reaguje na situaciju? Po tome, nemoguće je sudariti se.
Njima je odradio TCAS (RA) i oni su krenuli u manevar izbegavanja. Sistem javlja, a pilot manevar radi na ruke, iskljucujuci autopilot i autotrotl. Prema tome, izbegavanje nije automatsko.
Medjutim, treba da znas kada se javi RA, akcija mora biti trenutna (a sta ako spavamo :kuku: ?) jer RA proradi na 2,1 milju.
I na simulatoru ima dosta ljudi koji ne urade manevar iz prve,a da ne spominjem realnu situaciju.
U zemlji gde radim sam imao slucaj koji Cozmo pominje. Mi u odlasku, drugi avion u dolasku na isti aerodrom. Javio se Traffic Advisory, a mamlaz iz drugog aviona je krenuo u neku svoju proceduru izbegavanja kao da mu je proradio Resolution Advisory, i skrenuo u poniranju u (recimo) desno. Sta bi bilo da sam i ja bio ''pametan''. pa u penjanju skrenuo u levo?
Postovi: 5298
Re: Vazduhoplovi
Prvi 737 koji je otišao u večna lovišta. Isečen je. Slava mu.
BRABUS
Postovi: 551
Re: Vazduhoplovi
Post od BRABUS »
@zu
Čitao negde da Boeing izdaje Flight Crew Advice za Max vezano za nesreću u indoneziji. Šta je u pitanju?
Postovi: 5298
Re: Vazduhoplovi
Postovi: 4657
Re: Vazduhoplovi
BRABUS napisao: 07 Nov 2018, 09:48 @zu
Moja firma jos nista nije dobila, ali mi je muka kada citam ovo sto je Cozmo postovao.
Pametnije bi im bilo da resavaju problem u mesto da izdaju biltene. Msm, i izdavanje biltena (i uvodjenje vezbe na simulator) oni podrazumevaju kao resenje.
A biltena - kol’ko hoces.
Od prvog dana sam rekao da mi se MAX ne svidja.
Trebali su da naprave nov avion.
H4wkeye
Postovi: 8763
Lokacija: PO
Re: Vazduhoplovi
Post od H4wkeye »
Citam za ovaj Lion Air let pise da je na poslednja cetiri leta airspeed indicator bio ostecen. Plus sad ovaj bilten za angle of attack. Pitam se kako se ostetio airspeed indikator i kako to nije primeceno pre. A na poslednjem letu pre ovoga putnici kazu da je avion imao problem da odrzi visinu.
Postovi: 4657
Re: Vazduhoplovi
Problem je i ako firma nema dobre, edukovane, i iskusne mehose.
U predjasnjoj kompaniji nisu znali da zamene nova LED svetla na poslednjim modelima NG, a u sadasnjoj (kao verovatno i ostalim), novi MAX je prava enigma.
Mi smo imali samo kurs za NG/MAX differences a trebali smo i simulator - a nismo.
Da li su mehosi imali nekakvu obuku, ne znam, ali cisto sumnjam.
Postovi: 21170
Re: Vazduhoplovi
Postovi: 5298
Re: Vazduhoplovi
zuzazu napisao: 07 Nov 2018, 10:04 Moja firma jos nista nije dobila, ali mi je muka kada citam ovo sto je Cozmo postovao.
H4wkeye
Postovi: 8763
Lokacija: PO
Re: Vazduhoplovi
Post od H4wkeye »
I ne cudi me, koliko ljudi leti za Peking. Mnogo bolje bi funkcionisalo kad bi imali jos neku direktnu liniju sa na primer Amerikom ili Kanadom.
steva_anya
Postovi: 5456
Re: Vazduhoplovi
Post od steva_anya »
Kakvi su nasi mehanicari u odnosu na kolege iz okoline i sveta?
Ako se pokvari avion neke kompanije, nju popravljaju nasi ili oni salju svoje ljude?
Postovi: 4657
Re: Vazduhoplovi
Nasi mehosi, tu negde 40-50 god. starosti su bili vrhunski, pa su se udomili kojekuda.
Na zalost, ovi novi su razbucali i njih.
Ako se avion pokvari van Srbije, zove se tehnicko odrzavanje sa kojom AS ima potpisan ugovor. Oni resavaju problem, i fakturisu aviokompaniji.
Ako se avion salje u neku vukojebinu, onda ga prati i mehanicar, mada mi nikad nije bilo jasno sta moze da uradi sa srafcigerom i jednim kombinirkama.
BRABUS
Postovi: 551
Re: Vazduhoplovi
Post od BRABUS »
Plane drops 500ft in 18 seconds after error
The pilot of a Flybe plane that dropped 500ft (152m) in 18 seconds had selected the wrong autopilot setting shortly after take-off, an inquiry has found.
Some 44 passengers and four crew were on board the Belfast City to Glasgow flight on 11 January when the aircraft "pitched nose-down" towards the ground.
An Air Accidents Investigation Branch report said warnings alerted the pilot, who fixed the error at 928ft (283m).
Flybe said it had implemented "remedial actions quickly in response".
The report said that autopilot was engaged when the Bombardier Dash-8 Q400 turboprop plane reached an altitude of 1,350 ft.
The plane climbed to 1,500ft, but then pitched and "descended rapidly" because the autopilot was set with a target altitude of 0ft.
Staff reported that the plane "had become visual with the ground", and the report said the aircraft had reached a maximum rate of descent of 4,300ft/min.
The 60-year-old pilot "responded almost immediately" to cockpit alarms and disconnected the autopilot, the report found.
The flight continued as planned to Glasgow and landed without further incident.
The report said "several safety actions" had been taken by Flybe since the incident, including revisions to simulator training and amendments to the taxi checklist.
A statement from Flybe said the operator "maintains a rigorous approach to ensuring the very highest flying standards are maintained".
"Flybe implemented remedial actions quickly in response to the incident and our training and procedures have been amended to minimise the risk of a reoccurrence," it said.
Https://www.bbc.co.uk/news/uk-46137445
