Ratna tehnika
Re: Ratna tehnika
.Slika
maxer
Postovi: 6672
Lokacija: Zaječar
Re: Ratna tehnika
Post od maxer »
Juče je S.Koreja objavila da razmatra napad na teritoriju Američkog ostrva Guam, u Pacifiku, jer su odatle poleteli B-1 bombarderi, koji su u ponedeljak preleteli Korejsko poluostrvo (verovatno i logično iznad teritorije Južne Koreje) u cilju demonstriranja vojne moći Amerike a povodom zadnje balističke probe Severne Koreje.
SEOUL (Reuters) - North Korea said on Wednesday it is "carefully examining" plans for a missile strike on the U.S. Pacific territory of Guam, just hours after U.S. President Donald Trump told the North that any threat to the United States would be met with "fire and fury".
North Korea has made no secret of plans to develop a nuclear-tipped missile able to strike the United States and has ignored international calls to halt its nuclear and missile programs.
The strike plan would be put into practice at any moment once leader Kim Jong Un makes a decision, a spokesman for the Korean People's Army (KPA) said in a statement carried by the North's state-run KCNA news agency.
"The KPA Strategic Force is now carefully examining the operational plan for making an enveloping fire at the areas around Guam with medium-to-long-range strategic ballistic rocket Hwasong-12 in order to contain the U.S. major military bases on Guam including the Anderson Air Force Base," the spokesman said.
The plan would be reported to the North's Supreme Command soon, the spokesman said, without citing a date.
On Monday, two US B-1 bombers flew from Guam over the Korean Peninsula as a part of its "continuous bomber presence," a U.S. official said, in a sign of the strategic importance Guam holds.
In another statement citing a different military spokesman, North Korea also accused the United States of devising a "preventive war" and said any plans to execute this would be met with an "all-out war wiping out all the strongholds of enemies, including the U.S. mainland."
The United States should stop its "reckless military provocation" against North Korea to avoid any military action, the army spokesman said.
The U.N. Security Council unanimously imposed new sanctions on North Korea on Saturday over its continued missile tests.
Trump ratcheted up the rhetoric against North Korea on Tuesday, saying Pyongyang should not make any more threats against the United States in a meeting with reporters at the Trump National Golf Club in Bedminster, New Jersey.
(Reporting by Christine Kim and Soyoung Kim; Additional reporting by Idrees Ali in WASHINGTON; Editing by Lincoln Feast)
By Christine Kim and Soyoung Kim
ReutersAugust 9, 2017
https://www.yahoo.com/news/north-korea- ... 57124.html
Re: Ratna tehnika
Juce procijenili da imaju tehnologiju malih bojevih glava, sad kazu da razmatraju napad na Guam...jel to neki prolog u intervenciju ili nastavak kola?
maxer
Postovi: 6672
Lokacija: Zaječar
Re: Ratna tehnika
Post od maxer »
Jedno je sigurno: situacija eskalira ... a dokle će da dogura, zavisiće od stepena samozavaravanja Kim-a. Kod takvog lika, ne možeš reći da li je spreman ili ne (tj. da samo folira) ući u nuklearni sukob sa Amerima (ako uopšte ima "operativnu" nuklearnu bojevu glavu).
H4wkeye
Postovi: 8763
Lokacija: PO
Re: Ratna tehnika
Post od H4wkeye »
Heh, da li je on uopste svestan da ako bi stvarno napao Guam koje bi posledice bile po njih. Mislim, realno, Amerika ima moc da zbrisve Severnu Koreju kompletno... Ne znam kako im nije dosadno da svaki dan prete polovini sveta.
Postovi: 22170
Re: Ratna tehnika
Politička retorika. Drži narod u strahu.
Postovi: 4968
Re: Ratna tehnika
HKS napisao:Juce procijenili da imaju tehnologiju malih bojevih glava, sad kazu da razmatraju napad na Guam...jel to neki prolog u intervenciju ili nastavak kola?
maxer napisao:Jedno je sigurno: situacija eskalira ... a dokle će da dogura, zavisiće od stepena samozavaravanja Kim-a. Kod takvog lika, ne možeš reći da li je spreman ili ne (tj. da samo folira) ući u nuklearni sukob sa Amerima (ako uopšte ima "operativnu" nuklearnu bojevu glavu).
Gledajući kako su kroz razvoj nuklearnog oružja prošle Amerika i Rusija (prvo velike avionske bombe, a onda nekoliko faza smanjivanja dok nisu postale i jače i manje), lično mislim da Severna Koreja nema dovoljno malu nuklearnu glavu, koju bi mogla da smesti na raketu. U stvari, za sada su na nivou eksperimenta na zemlji - moguće je da nemaju ni avionsku bombu.
Razvoj rakete je nezavisna stvar od razvoja bojeve glave. Tu jesu pokazali izvesni uspeh, ali opet, nedostaje im treća stvar, koja je možda najteža od svega: tehnologija da nukleranu glavu opreme sistemom za navigaciju i upravljanje (tj. da naprave kompletan "re-entry vehicle"). To treba da se u nekom trenutku odvoji od rakete, nastavi let po balističkoj putanji i de-orbitira tačno u određeno vreme i padne na određeno mesto (a da pri tome ne izgori u atmosferi). Mislim da su oni godinama daleko od toga, ako ikada i uspeju da naprave.
Re: Ratna tehnika
Koliko godina je njima trebalo da razviju icbm? Mada, to su neka druga vremena.
Postovi: 4968
Re: Ratna tehnika
10 godina. Prva sovjetska nuklearna proba - 1949, a prva ICBM na svetu je bila sovjetska R-7, 1959. To je raketa koja je 1957. lansirala prvi satelit, 1961. prvog čoveka u svemir, a kao deo Sojuz programa se koristi do današnjih dana.
https://en.wikipedia.org/wiki/R-7_Semyorka
Pošto su Rusi i Amerikanci radili na svemirskom programu, jedna od osnovnih stvari koje su morali da reše je povratak broda na Zemlju. Rusi su došli do genijalne ideje da "brod" može biti nuklearna bomba, koju bi "spustili" na američku teritoriju. :D
Cica Maca
Postovi: 739
Re: Ratna tehnika
Post od Cica Maca »
Nije Tramp tolika budala, bice zbrisano pola Kine, ceo Japan a od Juzne koreje ni par stapica za jelo ostati nece.
Ovo je malo blize, i vidi se koliki su ovi turci, sto se rimuju sa ...... klasicne ....
http://len-ta.top/4-%D0%BC%D0%B8%D0%BD% ... %BC%D1%8C/
Sent from my HTC Desire 825 using Tapatalk
Postovi: 21236
Re: Ratna tehnika
Sa kojim resursima S. Koreja da vodi bilo koji rat? Jedino ako se spremaju da idu u rat za hranu.
Re: Ratna tehnika
^ ruskim i kineskim.
Postovi: 21236
Re: Ratna tehnika
Važi.
Re: Ratna tehnika
Pa zahvaljujuci njima i opstaju.
Cica Maca
Postovi: 739
Re: Ratna tehnika
Post od Cica Maca »
Severna K izvozi radnu snagu. Kroz svoje gradjevinske firme rade na gotovo svim kontinentima.
Poslednji primer je licno iskustvo. 2018 je svtsko prvenstvo u Rusiji. Rusi se u velikoj meri spremaju tako da je fela Moskva jedno veliko gradioiste. Sad bas vrtim u glavi, ali barem na 5 mesta sam video korejance, njihove firme i njihovu opremu. Ako i dobijaju ikakvu pomoc od nekoga sa strane, moj prst bi bio u pravcu Pakistana. Ali i ta pomoc je za DEBELE i MASNE dolare.
Sent from my SONY Experia mobile
