2018 Suzuki Jimny
Postovi: 49380
Re: 2018 Suzuki Jimny
5 vrata + hibrid.
Postovi: 49380
In Brazil a special variant has just been presented: 4Sport
Only 100 units
181,990 Brazilian reais (around €35,050)
Postovi: 49380
Postovi: 49380
Postovi: 49380
Postovi: 49380
Postovi: 49380
Pravo rešenje za vas sa viškom novca od prometa narkotika.
Italian tuning house Z.Mode has turned the Suzuki Jimny into an off-road pickup. The Jimny Next as it is called, will be built in just 22 units, with the company drawing inspiration from the Suzuki Samurai for its creation.
The new suspension increases ground clearance by 7.5cm, with the off-road tires adding an additional 2.5cm. It also has improved axles, differential guards and new anti-roll bars.
It has impressive ramp approach and escape angles: 51, 60 and 38 degrees respectively, with the company placing a roll bar behind the seats so as to increase the rigidity of the car. It has also been fitted with 15" rims, external air intake and a winch.
Its body is small in size and mechanically the 1,500 engine gets a turbo and produces 170 horses with 270 Nm of torque. The price of Suzuki Jimny Next starts from 62,222 euros.
Postovi: 49380
Postovi: 49380
Kažu zvanično.
Postovi: 49380
Newly added 5-Door measures 3,985 mm (157 in). Its wheelbase has been elongated to 2,590 mm (102 in), thus making it a substantial 340 mm (13.3 in) longer than that of the 3-Door variant. Maruti Suzuki says the vehicle is 1,645 mm (64.8 in) wide and stands 1,720 mm (67.7 in) tall, with both figures matching those of the international Jimny 3-Door.
With the rear seats up, it has a cargo capacity of 208 liters (7.3 cubic feet), which can be expanded to 332 liters (11.7 cubic feet) after folding the bench.
Postovi: 4659
Postovi: 49380
Jimny
Postovi: 18
Pridružio se: 11 Nov 2023, 11:00
Post od Jimny »
Pozdrav novi sam na forumu , imam Suzuki Jimny GLX 2022 model sa najvisom nivom opreme , vozim ga tacno godinu dana predjenih nekih 10 hiljada , utisci Auto je markantan, ostaje lep utisak i interesantan svako se okrece po njega izdrzljiv i pouzdan potrosnja mu je tacno 6,9 , auto koristim kako drugo alternativno vozilo u kuci i mogu reci da nije za duze putevi ja ne znam zasto je isto ovaj auto toliko skup ja kad sam ga video odma sam kupio i nije bilo nikakvih popusta jednostavno sam se zaljubio i kupio cekao ga nekih 8 meseca posto se sklapa u Japanu a ne u Madjarskoj po meni Auto je super za grad van grada i ostalo ko moze da kupi nece pogresiti mesto ima za cetvoro komotno ja sam zadovoljan ja kad sam njega video odma sam kupio i to je to , Auto ostavlja neverovatan utisak i verujte svako ga gleda haha , evo i nekih fotki pozdrav iz Makedonije .
Postovi: 16007
Dobro došao na forum.
Neka te automobil dobro služi.
P.S. Prvi post, pa ulazi u legendu foruma, kao jedna od najdužih rečenica ikada, sa 150+ reči bez tačke :D
paliic
Postovi: 267
Pridružio se: 20 Okt 2016, 09:33
Post od paliic »
Odličan auto! dobrodošao bratko
