Fabrički opozivi
Re: Fabrički opozivi
Nema opoziv, sad čitam
Jedan lik za limofirmu uzeo 150k W222, nisu mu pomogli.
Postovi: 49187
Volvo recalls 200,000 cars over fuel leak fears
https://www.autoexpress.co.uk/car-news/ ... leak-fears
Over 30,000 UK Volvos affected, although company says there are “no reports alleging injuries or damages related to this issue”
Volvo is recalling 219,000 cars globally due to a potential fuel leak, with 30,777 UK cars affected.
The recall relates to diesel-engined 2015 to 2016 model year examples of the Volvo V40, V40CC, S60, S60CC, V60, V60CC, XC60, V70, XC70, S80 and XC90 built between 2015 and 2016. In affected cars, a faulty fuel line could develop cracks, allowing fuel to leak into the engine bay.
Volvo sold 46,696 cars in the UK in 2016, and 534,332 globally, meaning a significant proportion of cars are affected. The company is “proactively” recalling the cars, so affected owners should be contacted over coming days and weeks.
Volvo’s recall of 219,000 cars follows a global action by Toyota in October last year, which saw 2.4 million previous-generation Prius and Auris recalled over a potential stalling issue. BMW, meanwhile, recalled 268,000 UK cars in 2018 over fears a potential glycol leakage from the exhaust gas recirculation cooler could lead to fire.
The Driver and Vehicle Standards Agency (DVSA) – the UK organisation responsible for monitoring recalls – recently told Auto Express it was considering linking its MoT and recall database. Some 2.39 cars are subject to an outstanding recall in the UK, almost a million of which are for potentially defective Takata airbags.
A spokesperson for Volvo told Auto Express: “Investigations by Volvo Cars have identified that some vehicles may have small cracks inside one of the fuel lines in the engine compartment. This, in combination with a pressurised fuel system, may over time lead to fuel leakage in the engine compartment.
“There are no reports of damage or injuries related to this issue. Volvo is proactively recalling these cars as a preventative measure to avoid any problems in the future.”
Postovi: 49187
Ne znam da li je bilo pomenuto već, VAG je opozvao sve benzince u SAD svih svojih brendova i besplatno menja komplet motore. Priznata fabrička greška sa potrošnjom ulja/ klipni mehanizam/.
Nisam ukapirao koliko godina unazad modeli su obuhvaćeni, mislim da su pomenuli u medijima zadnjih 15tak godina proizvodnje je tema.
To su objavili nemački mediji, u samoj Nemačkoj nema opoziva i vlasnici sami plaćaju zamenu motora.
klisko
Postovi: 666
Post od klisko »
Čime će da ih zamene? Identičnim novim motorima ili poboljšanim?
Heineken
Postovi: 6482
Lokacija: Šid, Srbija
Post od Heineken »
Imas neki link za tu vest ?
Novim tipom motora, gde je problem resen kao takav i vise se ne javlja.
Postovi: 49187
Ford recalls 322,000 cars in Europe over battery fire risk
https://europe.autonews.com/automakers/ ... -fire-risk
Ford is recalling about 322,000 cars in Europe whose batteries could potentially catch fire due to acid leakage.
The recall affects Mondeo, S-Max and Galaxy vehicles built between February 2014 and February 2019, a Ford spoksman told Automotive News Europe.
Ford said leaking battery acid around the battery's negative terminal could cause the battery monitoring system sensor to fail. As a result, the battery could overheat, presenting a potential fire risk.
In Germany, the company will recall 101,000 vehicles, and in the UK, 56,000, with the remainder spread across Ford's key European markets, the spokesman said.
Postovi: 49187
Volkswagen recalls 56,000 new Golfs
The Volkswagen announced it withdraws 56,000 new Golf constructed before July 2020 in order to place these new software to fix problems in the media and entertainment system and rear view camera.
Let me remind you that in May 2020 Volkswagen was forced to temporarily stop delivering the Golf for about 20 days, due to a problem with the e-call system software , which did not always work properly. In this case, too, Volkswagen fixed the problem by installing new software.
In the relevant news, Volkswagen stated that in 2020 it sold 134,000 purely electric models, 3 times more than what it had sold in 2019 (45,000). If the hybrid models are taken into account, last year the German company sold 212,000 electric models (hybrid and electric), compared to 82,000 in 2019.
Postovi: 49187
Škoda, Volkswagen, Seat and Audi have announced that they are recalling 63,328 of their cars (Seat Ateca, Tarraco, Audi Q2, Q3, Skoda Karoq, Kodiaq, VW Tiguan, Tiguan Allspace, Golf, Touran, T-Roc), 2020 production, bearing DSG gearboxes, as the brake pedal may break.
The cause is a faulty coupling that is stuck incorrectly, with the VW Group replacing the entire brake pedal. To date, the VW Group has not been aware of any accidents or injuries related to this problem.
At the same time, Skoda is recalling 1,458 Kamiq and Scala, produced in August and September 2019, because the eCall system button may not work.
BMW announced the withdrawal of 1,321,208 Series 3 production between July 20 2004 and July 8, 2011, and 3.235 Alpina B3 and D3 same production date, because the insulation of the plug of the fan controller wiring may be damaged over the years , something that could cause a short circuit, which could lead to a fire, even if the car is parked.
BMW is also recalling 83 X5 , X5 M , X6 and X7 built between 5 September and 18 September 2020, as the steering shaft may not be screwed in properly and there is a risk that it will fall out of place, which will result in its loss. steering system, thus increasing the risk of an accident.
Mercedes announced he withdraws 270.754 C-Class production between March 1, 2014 and February 28, 2018 equipped with four-cylinder gasoline engines in which the alternator could be heated excessively and cause fire.
At the same time, the German company is recalling 13,351 GLCs produced between January 12, 2018 and January 21, 2020, in which due to a defective screw, the positive pole of the 12V battery cable may come into contact with the starter and cause a short circuit.
In addition, Mercedes is recalling 592 GLBs produced between July 26, 2019 and January 25, 2020, in which the second row of seats may not have been properly secured on one side, which increases the chances of injury in the event of a collision.
Ford announced that it is recalling 10,145 Focus worldwide, produced between May 7, 2018 and July 5, 2019, because the engine wiring harness may come into contact with the gearbox brackets, causing damage to the harness and reducing engine power, and in some cases the engine may shut down, increasing the risk of an accident.
Postovi: 49187
122.000 Toyota Auris, RAV4, Avensis and Verso recalled in Europe
The Toyota made known to withdraw 122.000 Auris , RAV4 , Avensis and Verso in Europe because of possible coolant leakage from the EGR cooling system (Exhaust Gas Recirculation), which could cause a reduction in engine performance, even fire.
The cars to be recalled have been manufactured between March 2015 and May 2018.
Postovi: 49187
92,851 Opel Corsa and Corsa-e are recalled worldwide
92,851 Corsa and Corsa-e Opel is recalling them because the electrical grounding in them may be insufficient, which could lead to the unexpected development of the side airbag, increasing the risk of injury.
The affected cars have been manufactured between 2019 and 2021, with the recall affecting both 3-door and 5-door models.
Postovi: 49187
19,103 Fiat Tipo recalled
The Fiat withdraws 19.103 Tipo worldwide because the software of the airbag control unit may be defective and thus the airbags may not be activated in case of accidents, increasing the risk of injury.
This recall affects the Tipos built between October 31, 2020 and February 9, 2021.
Postovi: 49187
Mercedes recalls 1,538 A-Class and B-Class
Mercedes announced the recall of 1,538 A-Class and B-Class manufactured between August 26 and October 10, 2019. The problem is located in the condensate drain hose of the air conditioning system, which may be blocked, which may cause water to enter inside the vehicle.
As a result, any electrical components installed at the point where the water will enter could corrode and / or be short-circuited.
According to the company, as a result the SRS (Supplemental Restraint System) control unit could stop working, with the car may not be able to start, with the engine emergency operation activated while the car is in movement and operation of other components (eg fuel pump, automatic / manual emergency call) could be adversely affected, thus increasing the risk of injury and accident.
Postovi: 49187
Recall for 24,950 new Dacia Logan and Sandero
The Dacia revoke 24.950 Logan and Sandero manufactured between November 5, 2020 and December 23, 2020, because the cable hook hood retainer may be defective, thereby risking the hood to open while driving, increasing the risk of accidents.
To date, Dacia does not know of any accidents or injuries related to this problem, with the company replacing the defective cable with a new one.
