Opel Astra K
aviator
Postovi: 4112
Garaža: Peugeot 308 1.6 HDI
Re: Opel Astra K
Post od aviator »
Kako se ne brecaš?
Da je ovako Clarkson opiso Astru, strelj'o bi ga!
http://www.youtube.com/watch?v=svEd8y_w ... oO6a9cRvlh
Ful verzija http://www.dailymotion.com/video/x2im3gp
Postovi: 23580
Re: Opel Astra K
Ok, ovako cemo..
Ti si izneo misljenje da Opel prepakuje nesto i uvali ga kao nov prozivod. Ok, znaci ja sam magarac i naivcina jer sam taj isti proizvod kupio i smatram da nije prepakovan vec nov?!
"Opel-Popel :loool:" ?!
Wtf?! Kao imas govno auto jer Opel je sranje itd. Satro ne vredjam nikoga ko vozi Opel, samo kazem da je sranje...
aviator
Postovi: 4112
Re: Opel Astra K
Post od aviator »
Ko u opšte priča Astri J???
:kafa:
Postovi: 23580
Re: Opel Astra K
Ne pricam licno o sebi vec iz ugla vlasnika.
Nije ni bitno.
:masem:
Postovi: 49375
Re: Opel Astra K
Malo bolje fotke.
The new model is based on the GM D2UX/D2XX platform that underpins the 2016 Chevrolet Cruze and Volt plug-in hybrid. The German manufacturer tells that the lightweight vehicle architecture ensures weight savings of 120 to 200 kg (264 - 441 lbs) depending on the model and trim level.
The bodywork’s weight was reduced by 20 percent from 357 to 280 kilograms (617 lbs), which is a big accomplishment for a volume-oriented vehicle.
According to the manufacturer, the 2015 Opel Astra K is 4.37 meters long (roughly 5 cm shorter than it’s predecessor). In terms of height, the 1.46-meter K is approximately 2.6 cm lower than the Astra J. Despite the smaller body shell, inside there’s more room than ever. The wheelbase is 2 centimeters smaller, but the rear passengers enjoy an additional 35 millimeters of legroom thanks to newly designed seats and more distance between the front and rear seats.
Postovi: 22169
Re: Opel Astra K
Mislim da će iz daljine samo znalci razlikovati K i J od napred i sa strane.
ivica122
Postovi: 1526
Pridružio se: 26 Sep 2014, 21:30
Garaža: Honda Accord CL7
Lokacija: Pirot, Србија
Re: Opel Astra K
Post od ivica122 »
Meni se bas svidja, ali slazem se da moze da se pomisli kako je ovo samo FL. Barem ovako spolja na prvi pogled. Ono sto smatram kao znacajno za K je smanjenje tezine. Cini mi se da su Opeli poslednjih godina bas otezali. Astra J je najtezi auto u klasi.
Postovi: 11049
Re: Opel Astra K
Walkeru što se pališ jbt :D
Postovi: 23580
Re: Opel Astra K
Ne znam ni sam, veruj mi
Re: Opel Astra K
Trebala bi biti lakša, nova je platforma.
Postovi: 23580
Re: Opel Astra K
Okacio Geza brojke par postova iznad
Aca BG
Postovi: 1965
Re: Opel Astra K
Post od Aca BG »
U sustini napreduju, jedino mi zadnji kraj lepsi na J.
DW nemoj primati k srcu toliko, a razumem te. Da je Opel sranje, ne bi bio tu gde jeste.
dunx81
Postovi: 5754
Garaža: Civic 1.8
Lokacija: Zrenjanin
Re: Opel Astra K
Post od dunx81 »
Lepa mi je i spreda i od pozadi. Jedino mi je bočno gledano lepša J zbog ovog detalja:
Nekako mi je tu ostalo nedorečeno ali sve u svemu dobra.
starac vujadin
Postovi: 11476
Re: Opel Astra K
Post od starac vujadin »
Lepo izgleda...možda su mogli bez tih "Peugeot-Citroen" zajebancija s C stubom.
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Re: Opel Astra K
Post od Risto »
ok auto, i vise od toga, cekam da vidim auto uzivo...
drago mi je da auto vise nije toliko tezak, ocekujem napokon pristojne performanse i sa motorima ispod 150ks...
