Filmovi, serije, dokumentarci - preporuka za gledanje
Re: Filmovi, serije, dokumentarci - preporuka za gledanje
Sve to radi super jer je isti sors.
- maxer
- Postovi: 6672
- Lokacija: Zaječar
To se rešava (kod mene ih nema).grujicd napisao:...Ako bi već morao nešto da zamerim to bi bile reklame kojih ima u ovoj verziji.
Nije ništa komplikovano, mada tako možda deluje, odradi se za par minuta.
Ovaj prvi deo je malo nezgrapno/nepotpuno objašnjen ali mislim da ćeš se snaći da odradiš potrebne radnje, ako negde zapne - pitaj.
With uTorrent RUNNING:
1) Ctrl+Alt+Delete
In the running processes, right-click on utorrentie.exe (Windows 7) or webhelper (under background processes, windows 10) and click "Open File Location."
2) Right-Click on utorrentie.exe (or webhelper), click properties, go to the security tab.
3) Click on Edit, and click on Deny for "Full Control" on all of the users listed (including SYSTEM).
4) Go back to task manager and kill all instances of utorrentie.exe or webhelper
Congrats! No more Ads, and uTorrent no longer bogs down your computer!
Dopuna:
I ran into this as well and I tried what DIIS noted and that did not work. Because I found the folder that the malware would drop the utorrentie.exe file what I did was I stopped utorrent then went to the folder (the folder for me is below) deleted the executable utorrentie.exe and I changed all of the security permissions to deny for ALL users even admins for the folder. After changing the permissions I can't even go into the folder to see if the file is back. I restarted utorrent, I ran Windows Task Manager and after 20 minutes no utorrentie (webhelper) running and NO ads
C:\Users\xxx\AppData\Roaming\uTorrent\updates and select the latest update folder. Also, in utorrent, turn off program updates in permissions. If you don't the system will create a new update folder and but utorrentie.exe in that one.
Bez obzira na sve gore izrečeno, WebHelper i taj utorrentie.exe, su kod mene obavezno blokirani u firewall-u (koji god da koristiš, mislim da znaš kako se to radi). Oba programa ćeš naći na gore datoj putanji.
Evo kako izgleda kod mene (trenutno troši svega 40MB RAM-a i 0% CPU-a):
Mani me Nidzo tih tvojih teorija gde ti zamisljas kako nesto radi.
Pogledajte po netu, nisam jedini koji ima taj problem. Uostalom, skinite neki torrent veci od 100Gb, pa cete se i sami uveriti. Veci broj upload slotova je obavezan za postizanje nekog normalnig uploada.
Ja imam oko 10 torrenata preko 40Gb, 2 ili 3 preko 100.
Grujicu, te reklame mozes lagano da uklonis, pogledaj moj raniji SS, nema reklama. Pogledaj na netu kako.
Maxer, drzim upaljena oba u isto vreme, ne kolje me toliko utorrent ovako.
Sent from my D6603 using Tapatalk
Poslednja izmena od Xepoj87 u 29 Okt 2016, 00:17, izmenjeno 1 put ukupno.
- milospinkfloyd
- Postovi: 2015
- Pridružio se: 25 Maj 2015, 22:32
- Garaža: Mini Cooper S F56 - Brera V6 Q4
- Lokacija: subotica
Koji torrent si skidao velicine 250gb?
sve sezone serije neke u ultra full hd?
Imao sam i od 700Gb
Sada trenutno skidam South park 19 sezona, da nabijem upload.
- grujicd
- Postovi: 9326
Ma skida backup interneta, pusti ga
Evo kako to radi kada je torrent na idle, znaci nista ne uploaduje, sem smesnih 20Kb, a najveci torrent u listi je 40Gb, a sam uTorrent je upaljen mozda samo 10 sati, nije duze sigurno, a vremenom samo dize potrosnju rama.
Poenta je sto mi u Task Manageru pise da uTorrent trosi fazon 30-40mb, dok ga ne iskljucim, pa mi se nekada isprazni i do magicnih 12Gb rama
Stavite testa radi, neki torrent od 200Gb, neki pack igara ili filmova i serija da se skida, pa mi javite kako to ide
https://www.youtube.com/watch?v=UrHZmGt0sBM
Vidis ni ja ga nisam gledao, kao ni 21gram.
Moracemo to ispraviti. Verovatno je dobar, spada u klasike malte ne
Šta ti misliš koliko ti utorrent zauzima ram memorije?Xepoj87 napisao:Evo kako to radi kada je torrent na idle, znaci nista ne uploaduje, sem smesnih 20Kb, a najveci torrent u listi je 40Gb, a sam uTorrent je upaljen mozda samo 10 sati, nije duze sigurno, a vremenom samo dize potrosnju rama.
Pa ti mene zezas, nema druge
Po ovom snimku zauzima 1-2 GB rama a nije mi jasno šta ima veze koliko zauzima kad imaš toliko ram memorije?
Slobodna ram memorija je bačena ram memorija
Vidiš da desetka pokušava da kešira u ram memoriji ne bi li što bolje iskoristila ram memoriju.
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Херој,
Evo kako je kod mene, predpostavljam da je ovaj Win7 pravilno prikazao parametre u Resource monitoru (ja bar imam takva iskustva, da ovde ne greši):
To je ona mašina koja se ne gasi.
Izgleda da je to kod tebe posledica Win10-tke.
Možda je neka verzija bila sporna. Ne treba generalizovati, većina tih programa je isti izvor koda.
E da, odgledao sam prve tri epizode Timeless.
Laki sci-fi, nije uopste losa da se gleda.
- H4wkeye
- Postovi: 8763
- Lokacija: PO
Ja koristim QBittorrent i radi odlicno. uTorrent sam prestao odavno da koristim.
