Pri gasenju se radi neka vrsta "rekonfigurisanja / rekalibracije" panela, tako da ravnomerno bude opterecen.
Ne zelis da prekines taj proces :)
U NSu su ubili 2 komada u prodavnicama - info od ovlascenog servisa.
The patent is accessible via its Google Patents page, but in short, OLED panels must periodically run a self-correction process to correct irregularities in the voltage being supplied to areas of the panel, the visual result of which is uneven brightness across the screen surface. This process takes some time, during which the TV is inoperable, an inconvenience which might explain why manufacturers have been unwilling to previously disclose it. The higher the pixel count, the longer the process takes, which goes some way in explaining why we saw notably poorer screen uniformity when OLED TVs made the jump to Ultra HD resolution.
For the first time, LG have placed the option to run the self-correction process in the user menu (previously, it was only accessible in the service mode.) The menu is called “OLED Panel Settings” and has two sub-options. The first schedules a cleaning session for next time the TV enters standby mode. The second puts the television into standby mode and begins the process immediately, and then turns the screen back on when it’s ready for use again. It takes a little over an hour, and interrupting the TV before it’s finished will require you to start again. It seems logical that in addition to these, the same behavior as prior generations will be in effect, namely that the display will silently begin the process after three hours of usage have accumulated and the TV has been placed into standby.
Šta ako nestane struja?
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Post od Laki021 »
Ocigledno to nije bas normalno da se desi.
Zoves servis ako crkne...
LG jbg.
Čeka se Samsung :)
Postovi: 28268
Ako nestane struje bas u 30s od gasenja tva, proklinji sudbinu :D
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
To traje sat vremena.
Postovi: 28268
Wtf??? Sat vremena ne smes da iskljucis tv iz struje posle gasenja???
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Pa nigde to ne kaze, teoretski sme al eto Delija kaze da su navodno neke ubili tako, ko zna sta ih ubili.
Pride se to ne radi nakon svakog gasenja vec tipa svakog stotog.
Floyd napisao:Šta ako nestane struja?
Racunam da u Svici ne nestaje struja :), a meni je i ovaj TV na APC UPS-u.
Milos
Postovi: 9327
Post od Milos »
Delija napisao: a meni je i ovaj TV na APC UPS-u.
Delija je voleo uvek da sve podigne na jedan visi nivo ludila :mrgreen:
klisko
Postovi: 666
Post od klisko »
Jeste li čitali šta piše? Ako ga prekineš, onda mora ponovo, neće da crkne ako se jednom prekine. I radi to uvek nakon tri sata korišćenja, što je baš malo. Uglavnom, stigao DPF u televizore :)
Postovi: 33135
Koja glupost, da crkne tv ako ga prekineš u toj kalibraciji ili šta je već.
Velja
Postovi: 12135
Post od Velja »
klisko napisao:Uglavnom, stigao DPF u televizore :)
:plusone: :kezo:
Postovi: 9932
:kezo:
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Televizor radi!
Lepo izgleda. OK, nije to bas Samsung kvalitet izrade i detalja ali nije ni lose. Tesko mi je bilo da kupim LG proizvod, ali sta da radim kad Samsung tvrdoglavo odbija da pravi OLED, valjda ce im doci uskoro iz dupeta u glavu pa da zamenim.
Slika je dobra, dobra, bolja je od plazme. Moje crno je sada stvarno crno! Jeste crno odlicno i na plazmi ali je ovo ipak za nijansu crnje (plazmu kad upalite vidite da ekran malo posvetli). Sinoc pogledali The Croods, ufff, ko pravljen za demo OLED televizora, neke scene bas ostavljaju bez daha. Ne znam da li je zbog 4k ili plasme ali ovde nema grain efekta ni kad se gleda iz blizu (1m), kod plazme se to malo primeti, licno mislim da je to zbog razmaka izmedju pixela plazme, ali mozda i lupetam. Kad krene vatromet na crnoj pozadini, to je nevera kako dobro izlgeda. Pride nema onih random treperenja pixela koje se desava kod plazme, ne znam kako se to strucno zove. Statina slika koja je slaba tacka plazme (treperi) je ovde odlicna.
Nisam ga jos gledao po danu, ali cini mi se da to sto nova generacija ima panel sa osetno jacim max osvetljenjem ni malo ne skodi. Meni ce ovo biti OK, ali mogu da zamislim da nekome treba svetliji panel. Samo mi nije jasno kad gledam preporucena podesavanja ovog TV-a, stavljaju osvetljenje na tipa 53, ebem li ga kako je njima to OK. Menij je sada na 85 i mislim da cu ga gurnuti na 90 (za nocno gledanje). Mozda ako gledaju u mrklom mraku sa metar daljine.
Sve u svemu, rekao bih da je OLED pokupio sve najbolje od plazme i LCD-a bez ijedne mane sto se slike tice (ove propratne stvari kao sto su DPF regenracija i sl ebem li ga). Nisam jos jedino proverio uniformnost panela, ovako bez provere deluje super.
Sad sam bas nestrpljiv da gledam TV :)
