BMW 5 (G30) 2017
Re: BMW 5 (G30) 2017
Normalno je da kriju M5 kad neće on još godinu dana :)
Postovi: 49426
Skida kožu polako.
Kabal
Postovi: 3218
Garaža: Volvo XC60 D5 AWD
Post od Kabal »
Cenim da ce auto da bude bomba
Iz ovog ugla izgleda kao veliki F30.
Postovi: 49426
2017 5 Series Colors, Interior and Ordering Guide Official Details
http://www.bimmerfest.com/news/923611/2 ... e-official
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Post od Laki021 »
Bas mi sa svih slika deluje da je dosta porastao.
U ponudi ce imati i all-season 19-ice :srbin:
http://www.bimmerfest.com/pdf/bmw-prici ... -Guide.pdf
Postovi: 49426
he BMW Group is the first automobile manufacturer to introduce a unique system concept with a fully-automated, optical measuring cell in its pilot plant in Munich. Freely moving robot arms use sensors to create a three-dimensional image of the entire vehicle and generate a 3D data model from the data captured, with an accuracy of less than 100 µm. This allows barely visible deviations to be identified at an early stage.
The optical measuring cell is deployed at the interface between development and series production. It forms part of the BMW Group’s digitalisation strategy for production and supports the high quality standards for production of premium vehicles. The next generation of the BMW 5 Series Sedan will be the first to benefit from this new technology.
Eduard Obst, Head of Geometric Analysis, Measuring Technology and Cubing, Total Vehicle, explains: “We are delighted to reach this genuine milestone in preproduction with the optical measuring cell: A single measurement provides us with a 3D data model of the total vehicle. Lengthy individual measurements and data collation are no longer needed – saving time and enhancing quality at the start of series production.”
A robot arm on rails mounted on each longitudinal axis of the optical measuring cell moves freely as it maps the vehicle in complete space. Occupying a relatively small area, this set-up allows two small, flexible robots to be used in parallel in an optimum working range. Compared with previous processes, in which robots use a single sensor to record one side of the vehicle after the other, measurements now only take around half the time and are completed within just a few days.
The robots are fitted with two sensors that record reference points and then capture individual surface areas of approx. 80 x 80 cm each. These are combined to form a scan of the entire vehicle. Analysis of the data quickly reveals any deviations, allowing technical integration specialists in the Production division to take appropriate action early on.
Three-dimensional vehicle scanning can be fully automated and performed at off-peak hours or at night, so the measuring cell can be utilised to full capacity. With results delivered promptly, update cycles are shorter or no longer needed. The measurement data and analysis findings are shared online within the production network and also made available to the plant responsible for series production to assist with their preparations.
The fully-automated optical measuring cell is gaining increasing importance within the BMW Group. This technology has been successfully used in toolmaking in Munich since 2015 for complete measurement of individual sheet-metal parts, as well as tool inspection.
The BMW Group is currently exploring the use of automated optical measurement at its automobile plants.
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
BMW’s upcoming 5 Series range will bring forward a couple new models. Among them, we’ll get to see a new M Performance automobile under the …
BMW’s upcoming 5 Series range will bring forward a couple new models. Among them, we’ll get to see a new M Performance automobile under the M550i nameplate which will most likely replace the popular 550i. This new variant will be a proper rival for the Audi S6 as well as a perfect fit to fill in the performance gap leading up to the M5.
According to our sources inside Munich, BMW is working on two versions of the M Performance model that will be available within the 5 Series range. One of them will be coming with all-wheel drive for those looking for straight line performance while the other will be rear-wheel drive for those enjoying twisty roads. Both cars, however, will be using reworked versions of the N63 4.4-liter V8 engine. No definitive horsepower figure is known at the moment but we should expect close to 500 HP and 700 Nm (516 lb-ft) of torque.
Uf, kad bi ovo bilo istina ovo bi pokopalo i E43 i Panameru 4S... jos uvek sve sama kontradiktorna nagadjanja.
Evo ga malo na Ringu.
https://www.youtube.com/watch?v=YEmVnVDaghI
Comi
Postovi: 1182
Pridružio se: 11 Nov 2014, 09:49
Post od Comi »
Ne ulazim u temi vise do Septembra.
Ma u PM vise sa 5838 maskiranih slika do podne.
Dobra sisa zlata vredi.
Postovi: 49426
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Pa evo i ja sam se malo igrao sa PS... isto cisto nagadjanje.
Jasno na osnovu boja se vidi da je ovo M Performance verzija.
Postovi: 49426
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Opa bato, gornji deo gepeka bez kamuflaze! Striptiz je poceo :)
Postovi: 49426
https://www.youtube.com/watch?v=gLRG8XQKruw
