Dobro veče
maniaxxx
Postovi: 6558
Re: Dobro veče
Post od maniaxxx »
Sretan put. U SLO ne bi trebalo da bude problema ako ne bude neke nesreče, Ako bude onda piči na alternativne GP...
kragujevac
Postovi: 3512
Garaža: Jaguar XF 4.2 V8 (NA)
Lokacija: Minhen/BRD
Re: Dobro veče
Post od kragujevac »
Hvala. Videćemo kako bude bilo usput, ako ne bude smak sveta rado bi svratili u Maribor.
Ljuba Moljac
Postovi: 23565
Re: Dobro veče
Proba fontane.. :kuku:
maniaxxx
Postovi: 6558
Re: Dobro veče
Post od maniaxxx »
Mislim da če biti sve OK, nadam se samo da nečete naleteti na neko nevreme, u tri dana dva puta smo imali nevreme ovde kod mene. Juče je bilo baš gadno, grad mi je oba avta oštetio i oba su do polovine točka plivala u vodi, toliko je kiša padala.
Re: Dobro veče
Floyd napisao:
ikac2000 napisao:Isto na primer, dok je UK u EU, ako clanovi porodice sa SRB pasosem putuju zajedno sa clanom sa EU pasosem, mogu da prodju sa njim bez vize, ili vizu dobijaju direktno na granici.
Naravno da ne može.
Zvanicno:
http://europa.eu/youreurope/citizens/tr ... dex_en.htm
Korekcija, tj nisam naveo, ukoliko poseduje residence card eu family member koja je izdata u nekoj EU zemlji, moze bez vize.
Sample storyHolders of an EU family member's residence card don't need to obtain a visa if travelling with an EU national
Ying, the Chinese spouse of a German national living in Finland, has been issued an EU family member's residence card in Finland. Ying and her husband wish to travel to Romania for an autumn break. As Ying has a valid passport and an EU family member's residence card, she is not required to obtain an entry visa to travel to Romania with her husband.
Re: Dobro veče
Da ali za UK to ne važi. Imaš i na tom tvom linku...
Even if you have a residence permit, an entry visa is needed to travel to a non-Schengen country
Joyce, a Nigerian national, lives in the Netherlands with her Dutch husband Luuk. As a family member of a Dutch national, Joyce has been issued a residence permit in the Netherlands. Joyce wishes to join Luuk on his next business trip to London. As the UK is not part of the Schengen area, Joyce is required to obtain an EEA Family Permit (an entry visa) to travel to the UK with Luuk.
Re: Dobro veče
Arriving at the border without an entry visa
It is always best for your non-EU family members to be well informed in advance and have all the necessary documents before starting their journey.
However, if they arrive at the border without an entry visa, the border authorities should give them the opportunity to prove by other means that they are your family members. If they manage to prove it, they should be issued with an entry visa on the spot.
Re: Dobro veče
Možda u Šengenu i to u nekim posebnim situacijama. U UK nema šanse da dobiješ vizu na granici, osim tranzitne na 24 sata.
Edit: Izgleda da si delimično u pravu.
https://www.gov.uk/government/publicati ... dence-card
Po ovome ispada da ne-eu supružnik npr. rumunskog državljanina u Nemačkoj, može u UK bez vize a ne-eu supružnik nemačkog državljanina, ne može :)
To je zato što su EU zakoni iznad domaćih.
Re: Dobro veče
https://youtu.be/1RJze4yIfDY
E ona je bas za G klasu 4x4
Postovi: 28261
Re: Dobro veče
Slupala Ferrari 458, pa keva skontala da joj treba nesto robusnije :D
Ali, ako nista drugo, vozila je na ovom snimku offroad vise od 99% vlasnika te G klase :)
Re: Dobro veče
Ima li kod benzinaca smisla ono hladjenje turbine posle duze I brze voznje, pre gasenja motora ? I koliko to treba da traje ?
Velja
Postovi: 12135
Re: Dobro veče
Post od Velja »
Isto važi za sve turbo-motore, bar 5 min.
Postovi: 15309
Re: Dobro veče
Nesto mi mnog 5 minuta. Rekao bih da je minut, dva dovoljno.
Sent from my SM-G900F using Tapatalk
Re: Dobro veče
Valjda se turbina ohladi ako nekoliko stotina metara lagano vozis do kuce. Nema potrebe da se drzi u leru, cak sam negdje procitao da je to losije.
Postovi: 14151
Re: Dobro veče
Ma kakvi, bar 10 minuta mora da radi u mestu inace strada turbina i radilica.
