2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Razvojni put francuske Corse.
Postovi: 23579
2019 Opel Corsa
Jbte i menjač su sjebali (ručicu).
Tipično francuska
Postovi: 49239
Re: 2019 Opel Corsa
Postovi: 49239
Re: 2019 Opel Corsa
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Re: 2019 Opel Corsa
Post od Risto »
Ekstra su je odradili, bravo Nemci (ovaj Francuzi)...
Postovi: 23579
Re: 2019 Opel Corsa
Ne vide se fotke preko TTa.
Risto
Postovi: 6023
Re: 2019 Opel Corsa
Post od Risto »
Kod mene radi preko TT-a :D
STrider90
Postovi: 161
Pridružio se: 16 Sep 2017, 17:08
Re: 2019 Opel Corsa
Post od STrider90 »
Ja ih vidim, baš dobro izgleda.
Postovi: 49239
Re: 2019 Opel Corsa
Za one sa jeftinijim ulaznicama.
2020 Corsa is 4.06 meters long, with a 2,54 (+28mm) wheelbase and much shorter overhangs. In addition, it's 48mm lower for better stability, while cargo capacity has grown to 309 liters.
Using the CMP platform, Opel has managed to make the Corsa up to 108 kg (238 lbs). This comes from using Peugeot's aluminum engines, but also a 40kg lighter body. Speaking of engines, only two displacements will e available, 1.2 liters for gasoline units and 1.5 for the diesel.
The former will have 75, 100 and 130 HP, while the diesel will only be available with 100 HP, at least at first. Initial impressions suggest that although slightly down on power, the top 130 HP model is faster and more responsive than Opel's old 1.4 Turbo. The 8-speed automatic will show a substantial improvement over Opel's sluggish unit.
Postovi: 23579
Re: 2019 Opel Corsa
Vrvatno ove fotke:
https://www.autoexpress.co.uk/vauxhall/ ... -spy-shots
