Fotografija
igor_harris
Postovi: 2210
Garaža: 2004 Mazda 3 (1.6CD)
Re: Fotografija
Post od igor_harris »
Prelazak na 5d3 je vec poceo da se isplacuje :)SlikaSlikaSlika
Milos_kg
Postovi: 3525
Garaža: Alfa 147 1.9 16v JTDm
Lokacija: Kragujevac
Re: Fotografija
Post od Milos_kg »
Odlične slike!
P30pro post
Postovi: 33126
Re: Fotografija
Odlično. Druga mi je posebno dobra.
Postovi: 4659
Re: Fotografija
The new Voigtländer 50mm FE is the sharpest lens ever tested by Marc Alhadeff
The Voigltänder 50mm F2 Apo Lanthar is an exceptional lens which redefines what sharpness is on A7RIV. It excels at close distance for portrait (very good color rendition and smooth background) and is excellent for distant subject like landscape or architecture with an incredible level of detail and an excellent contrast. Its small form factor and very good ergonomics make it a pleasure to use on day to day
The only other lens that can come close to this optical quality for a 50mm is the Sony Planar T* 50mm F1.4 Zeiss which share similar sharpness in the centre but is less consistent that the Voigtlander. However its F1.4 aperture & AF and smoother rendering will please more to the majority of photographers
If you looking for the best 50mm for portrait and street landscape and you are ok with manual focus and F2 , this is the best lens you can get
BAJKER
Postovi: 6086
Re: Fotografija
Post od BAJKER »
Nisam ni sumnjao da se taj objektiv nece naci kod tebe na telu aparata.
Malo smo se igrali CB foografije by Bajker
upload a pic
Milan
Postovi: 551
Pridružio se: 29 Apr 2012, 16:50
Lokacija: Stara Pazova
Re: Fotografija
Post od Milan »
Samo da se pohvalim da sam prodao kombinu iz oglasa, D5100 + 18-105 i prešao na fuji, XT-20 + 18-55.
Sunce ti, kida fuji. Kida. Čist sex fotkati sa ovim sistemom, ergonomija, estetika, osećaj pri korišćenju 10+, srećom, performansa ne manjka.
Milos_kg
Postovi: 3525
Re: Fotografija
Post od Milos_kg »
Postovi: 33126
Re: Fotografija
Milan napisao: 05 Feb 2020, 13:06 Samo da se pohvalim da sam prodao kombinu iz oglasa, D5100 + 18-105 i prešao na fuji, XT-20 + 18-55.
Ozbiljna igračka. Vidim nje ni tako skup.
Milan
Postovi: 551
Re: Fotografija
Post od Milan »
trojanac napisao: 08 Feb 2020, 09:30
Ja sam platio kombinaciju 740 ali sam se cenjkao prvo na KP, a posle i u radnji. Dva puta su mi spustili cenu. Na sajtu je npr samo objektiv 330e. Tako da šta znam, nije ni jeftino. mada sam odlično prošao jer je preko npr kod Mađara ta kombina 900+ eura.
Milos_kg
Postovi: 3525
Re: Fotografija
Post od Milos_kg »
Ja se upgrade-ovao na X-T2. Odličan je Fuji, možda i najbolji u crop senzor grupi.
X-T20 prodajem, pa ako je neko zainteresovan, nek cimne na pvt (nešto manje od 7k slika na electronic shutter, kao nov).
P30pro post
Postovi: 5300
Re: Fotografija
Jedna od sinoć.
Re: Fotografija
Pitanje
Prijatelju treba foto aparat kojim ce da slika slike koje mu trebaju za prijemni. Treba da slika 3 pejzaza, tri portreta i 3 mrtve prirode.
Razmisljam da predlozim Canon G7X MKII ukoliko se ne ide na DSLR.
Ukoliko bi isao na DSLR, sta je razumna kombinacija?
Gesendet von meinem SM-T580 mit Tapatalk
Postovi: 9323
Re: Fotografija
Prijemni za šta? To bi mogao i skoro svakim modernijim mobilnim, pretpostavljam da nije poenta u tehničkoj perfekciji već da pokaže da ima oko za kompoziciju, portret i mrtvu prirodu može malo da osvetli dodatno...
Re: Fotografija
Ne znam, verovatno za neki umetnicki faks.
Kako sam i sam u tim vodama oko 30 god, verujem da DSLR i odgovarajuce zarisne duzine pruzaju najbolju kontrolu, samo ne znam sta je sada aktuelno kao razuman izbor. Meni je vreme stalo na Canon 40D sistemu i 50 mm f1.4.
Telefon je za nasu svakodnevnocu OK, ali je ipak mogucnost kontrole na strani aparata.
Postovi: 9323
Re: Fotografija
Pričam samo za tu namenu par slika za prijemni. Nekako mi taj Canon G7X na prvu loptu deluje kao loša opcija za njega, jer nema fleksibilnosti koja će mu kasnije trebati ako krene ozbiljnije da se bavi fotografijom.
