Vesti iz auto-industrije
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Re: Vesti iz domaće i svetske auto-industrije
Post od Risto »
Cini mi se da nisu unapredili najslabiju kariku, enterijer, kada vidim ovu plastiku ispod menjača čini mi se kao da gledam Punta a ne Alfu...
Postovi: 49392
Da l' je realno da neko napravi ovakav volan :kuku:
Postovi: 13961
Definitivno je prva verzija originalnija. Motore su sredili ali unutrasnjost nikako. Spolja i nije bilo potrebe za cackanjem.
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
Mogli su farove da poprave
Sent from my MI 4LTE using Tapatalk
Risto
Postovi: 6023
Post od Risto »
http://www.worldcarfans.com/11602251043 ... 4-lbs-diet
Lotus Evora Sport 410 brings extra 10 hp, 154-lbs diet
Lotus has taken the wraps off the Evora Sport 410 which comes with a healthy weight loss of 154 pounds (70 kilograms).
The Hethel-based sports car manufacturer is on a roll these days as after coming out with the Elise Cup 250 , Lotus is now unveiling the Evora Sport 410. As the name of the car suggests, it brings an extra 10 horsepower (7 kilowatts) compared to the Evora 400.
Output of the supercharged 3.5-liter V6 now stands at a respectable 410 hp (306 kilowatts) at 7,000 rpm and a peak torque of 302 pound-feet (410 newton meters) reached at 3,500 rpm.
Aside from gaining more muscle, the Evora Sport 410 is also a significant 154 lbs (70 kg) lighter than the Evora 400 thanks to an abundance of carbon fiber components. It now tips the scales at only 2,921 lbs (1,325 kg) and this diet was partially possible by installing new lightweight door trim panels and a simplified carbon fiber tailgate.
As a result of the more power + less weight combo, the Evora Sport 410 will run the sprint to 62 miles (100 kilometers) per hour in 4.2 seconds before hitting 186 mph (300 km/h) when configured with the standard manual gearbox. Go for the optional automatic transmission and the sprint is achieved 0.1 seconds quicker, but the maximum velocity drops to 174 mph (280 kph.)
Lotus’ engineers have also fiddled around with the suspension by improving its geometry and overhauling the damping while the ride height has decreased by 5 mm. It sits on 19-inch front & 20-inch rear 10-spoke lightweight forged aluminum wheels that can be optionally had with Michelin Cup 2 tires.
The British marque mentions global production will be capped at 150 units annually and the car will hit major markets from June. A US-spec Evora Sport 410 is slated to arrive later this year. Pricing has already been revealed for some of the most important markets: £79,900 in UK, €106,900 in Germany, €107,800 in France, €111,960 in Italy, and ¥14.8M in Japan.
The Lotus Evora Sport 410 will be on display in Geneva starting next week alongside the Elise Cup 250, 3-Eleven , and a mysterious model that could turn out to be the Evora 400 Roadster.
Source: Lotus
Postovi: 49392
Citroën C6 II (Kina)
Postovi: 25272
Lambo Centennario
Postovi: 49392
Spyker C8 Preliator
Postovi: 13961
Spyker :ludilo:
Postovi: 49392
Pagani Huayra BC
https://www.youtube.com/watch?feature=p ... iEbyPFODDk
Borgward BX6 TS i BX5
Postovi: 49392
Alfa Romeo MiTo FL
Fiat 500S
Postovi: 49392
Galerije fotografija sa sajma u Ženevi.
http://www.salon-auto.ch/fr/photos/
Risto
Postovi: 6023
Post od Risto »
Ima li najava iz FCA za nove automobile A/B segemta? Gledam ovaj Mito i Fiću, lepi automobili ali opet verujem da bi se mnogo bolje prodavali novi modeli od FL verzija. Za Grande Punto je i Bog zaboravio kada je izašao :D
Neverovatno kakav sitan fl Alfe dozivljavaju. Pa ti modeli su dosta stari, trebali su uraditi ekstremni fejslift (kao npr w212 mercedes).
