2016 Mercedes E Class (W213)
Re: 2016 Mercedes E Class (W213)
With the fifth generation of the E-Class, Mercedes-Benz ticks all the boxes. The new business sedan not only sets higher standards for all its competitors, catering to anyone who wants to get an almost autonomously running computer, but also a saloon with a powerful design, matching performance and exceptionally luxurious interior.
Opposite to its predecessor, the new Mercedes-Benz E-Class is set apart by its more generous external dimensions: the wheelbase has grown by 65 mm to 2,939 mm and the length was expanded by 43 mm to 4,923 mm. Not the same can be said about the weight, thanks to lightweight construction. Short overhangs, long wheelbase, long hood, large wheels, a reinterpreted side character line characterize the design. With a drag coefficient of 0.23, the body proves not only aesthetic qualities, reducing the consumption and the noise level in the interior.
At launch, the E-Class will be available in two engine guises: the E 200 with a four-cylinder turbo petrol engine and the E 220 d powered by an all-new four-cylinder diesel engine with piezo-guided direct injection (code named OM654). After the market launch more models will complement the range. These include the plug-in hybrid E 350 e with an electric driving range of 30 km. Its four-cylinder 2.0-liter turbo gasoline engine works in conjunction with an electric motor for a system output of 205 kW/279 hp and a torque of 600 Nm.
The pinnacle of the new E-Class range will be the all-new 2-liter diesel engine (code named OM654) which comes in two flavors: 110 kW / 150 hp for the E 200 d (not available right from the outset) and 143 kW / 195 hp for the E 220 d launch model with a combined NEDC fuel consumption of 3.9 liters per 100 kilometers. This corresponds to CO2 emissions of 102 grams per kilometer. During the course of 2016, Mercedes will extend the line-up with new six-cylinder petrol engine (codenamed M256) and diesel engine (codenamed OM656). New from the ground-up, these units have already entered pilot production at the factory in Unterturkheim.
The new four-cylinder diesel engine (OM654) and the new six-cylinders petrol (M256) and diesel (OM656) will share elements of their architecture with the existing four-cylinder petrol engine (M274) including 500 cmc cylinder displacement and 90 mm distance between the cylinders axles.
On the petrol front, the 2017 Mercedes-Benz E-Class will be offered alongside a wide range of four-cylinder turbo engines with power outputs ranging between 135 and 180 kW (183-245 hp) and the aforementioned six-cylinder petrol engine said to be developing 245 kW / 333 hp. All engines are equipped with start-stop function. The petrol engines fully comply with the emission regulations according to EU 6, the new four-cylinder diesel engine is already designed for future limits. All models available at launch are fitted as standard with the new nine-speed automatic 9G-Tronic transmission.
The new E 63 AMG will debut in summer of 2016 powered by the new twin-turbo 4.0 litre V8, offered in two versions, with around 600 hp for the top version S.
In conjunction with the standard steel suspension, clients will be able to specify no less than three Direct Control Suspension options with selective damping system: a comfort suspension, a comfortable Avantgarde suspension with sportier character, lowered by 15 millimeters, plus an overtly sporty suspension with adaptive damping and a further 15 millimeters reduction in ride height. Alternatively, the 2017 Mercedes-Benz E-Class can be equipped with an air suspension complemented by an electronically controlled adjustable damping system. The E-Class is the only vehicle in its segment with a multi-chamber air suspension, called Air Body Control. The character of the E-class can be switched accordingly in five different modes via the standard Dynamic Select: ,, Comfort “, ,, Eco,” ,, Sport “and ,, Sport +” and the additional setting ,, Individual”.
Inside, the seats acts as a focal point. With their ergonomic shape the seats combine long-distance comfort with a sporty look and differ in terms of looks depending on the chosen equipment Line. The rear seat bench can be supplied on request with a three-part folding backrest (40:20:40). The center armrest includes a storage compartment and two cup holders. If desired, the interior is dominated by two large displays, each with 12.3-inch in diagonal. Visually the two screens merge seamlessly under a common cover glass and a single scoop in a cockpit, which seems to float freely.
For the first time, Touch Controls mounted on the steering wheel appear on a large scale production vehicle. As the surface of a smartphone they respond to horizontal and vertical swiping movements. Thus they allow the control of the Infotainment system via finger-swiping movements. In addition, the driver can use the classic touchpad and the controller on the center console, which recognizes handwriting inputs.
The standard E-Class versions will get traditional analogue dials and an 8.4 inch central infotainment screen.
The sedan will not be alone for long, of course, as the new E-Class line-up will reunite the Limousine (March 2016), T-Model (mid-2016), Coupe (March 2017) and Convertible (September 2017) variants.
And this is not all. In addition, Mercedes is working on a fifth derivative of the E-Class, the successor to the CLS (March 2018) and – instead of the Shooting Brake; the revolutionary AMG GT4 based on Mercedes junior supercar (september 2018).
The high standards that embody the E-Class become even more clear when looking at the impressive list of driver assistance systems. One area the new Mercedes E-Class will make a significant leap forward is the safety and comfort with various systems for semi-autonomous driving taking center stage.
Completely new on board are the Intelligent Drive Next Level and the Evasive Steering systems, semi-autonomous functions that can – at any time; be overridden by the driver. Also new to the E-Class is the Active Brake Assist with junction function. In addition, the E-Class is also offering industry first Car-to-X communication capabilities based on the wireless technology, fully communicating with other cars similarly equipped and warn the driver, brake or act accordingly to the imminent dangers. As an option, the new E-Class can also be remotedly controlled via a smartphone app for parking manouevres. The smartphone can be used to open or close the doors. The driver will be able to secure the car when leaving for a brief moment such as in a garage door opening scenario.
Intelligent Drive next Level is the next step to the autonomous driving. The system is able to keep the car at a correct distance behind slower vehicles ahead automatically and can also follow them in their lane at a speeds from 0 of up to 200 km/h. At speeds up to 130 km/h, the system is not dependent on clearly visible lane markings as it can also intervene if the lines on the road are unclear or there are no lines on the road at all.
If the Comand Online is ordered, the optional Speed Limit Pilot subfunction can autonomously adjust the vehcicle’s speed according to informations received from the camera detected speed limits.
Active Lane Change Assist (a sub-function of DRIVE PILOT and a component of the Driving Assistance Package) steers the new E-Class into the adjacent lane when the driver activates the turn indicator for more than two seconds, if sensors do not detect any vehicles in the relevant safety zone. It is also inconsequential whether the vehicle wants to return to the right-hand lane or steer to the left for overtaking. It works at speeds between 80 and 180 km/h (50-112 mph), when the Steering Pilot is activated.
Active Brake Assist can warn the driver of imminent crash situations, provide just the right level of assistance in the event of sudden braking and also apply the brake automatically in an emergency. In adition to detecting the slower-moving and the stationary vehicles, it also detects and reacts to crossing traffic at junctions, the tail ends of traffic jams and pedestrians. The Active Brake Assist is active in a speed range from 7 up to 250 km / hr for moving objects and from 7 to 70 km / h for stationary objects. Under optimal conditions, the system is fully able to prevent a collision on a stationary vehicle or a collision with pedestrians up to a speed of about 65 km / h. Cross-traffic collisions should also be avoided thanks to the intersection function at speeds as high as 50 km / h. In traffic jam scenarios, the Active Brake Assist is able to automatically stop the car from a speed of maximum 90 km / h.
Evasive Steering Assist is the ideal complement to the pedestrian detection function of Active Brake Assist. When the driver deliberately or instinctively performs an evasive manoeuvre in a dangerous situation, this function can assist by adding precisely calculated steering torque to support the movement of the steering wheel.
Remote Parking Pilot can park the car or take out the car from the parking space with the driver staying outside the car and using a smartphone application. It helps in the situations in which parking space is very tight.
Car-to-X Communication allows the mobile phone-supported exchange of information with other vehicles further ahead on the road, for example, can effectively allow the driver to see around corners or through obstacles. This means that the driver receives an earlier warning than previously in the event of imminent danger, such as vehicle in an accident.
Digital car key allows the driver’s smartphone to be used as a vehicle key.
Pre-Safe Impulse side system offers additional protection in case of side collision is detected. The air chambers in the backrest side bolsters inflate rapidly to prevently move the occupant sideways, away from the danger area. This increases the distance between passenger and door.
Pre-Safe sound protects the passengers ears from the expected noise in the event of a possible collision.
Multibeam LED headlamps each with 84 high performance LEDs automatically illuminate the road with precision controlled distribution of very bright light without blinding other road users.
Last but not the least on board are the already known systems like Active Lane Keeping Assist, Active Blind Spot Assist and Pre-Safe Plus, all of which were recalibrated in therms of their functionality and sensor accuracy. Airbags are integrated into the outer rear belts, a feature already on offer for the S-Class.
source:mercedesblog.com
Scuderia
Postovi: 13495
Post od Scuderia »
Meni samo S ok, a faceliftovi uz neko natezanje su malo popravili odredjene modele, CLS-a pokvarili. Oni ''jajasti'' modeli W211, CLK, prvi CLS su meni bili sjajni i Mercedesovski, ali verovatno je to subjektivno. I delovali su mi kvalitetnije u smislu izrade, ali tu nemam iskustvo da sam direktno poredio pa da mogu da tvrdim.
Od novog A ovo sto izbacuju mi je brutalno, jedino sto su identicni, mada meni to nikad nije smetalo.
Jbt jos malo i 5 metara E segment.
Postovi: 28268
Naravno, ukus je uvek subjektivna stvar :)
Vidim da izbacuju manuelni menjac totalno iz E klase :)
Napokon da automatik ne mora da se doplati :)
Dakle, motori ostaju u sustini isti, osim 2.0 dizela i AMG-a, a ocekivao sam pojacanje vecine motora.
Sviđa mi se 9g tronic ali mi se je sviđa što prvo ponude dva motora a posle svakih meseci ubacuju još neki...
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
Ja sam jedini kom se prošli model pre fl svidja :D
Sent from my MI 4LTE using Tapatalk
Ralee
Postovi: 3508
Post od Ralee »
Nisi :)
Ja sam dao pare za njega, tako da moram da pricam da je lep. :kezo:
Postovi: 28268
Solidan je on spolja, i ako se meni svidja samo uz amg paket, ali je enterijer previse nekako ojadjen.
Fl je to sve popravio.
Sent from my Sony
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
Meni je bio dobar dok se nije pojavio fl model i BMW f10 :)
Scuderia
Postovi: 13495
Post od Scuderia »
Znaci dok nije ni imao konkurenciju :kezo:
Postovi: 49388
https://www.youtube.com/watch?feature=p ... VXRo_TErCc
https://www.youtube.com/watch?feature=p ... GWeZj9PJLo
Postovi: 28268
Vrh :doubleup:
Sent from my Sony
Kakva vrh igračka :)
Postovi: 28268
Tacno se vidim u E kupeu za 6,7 godina :D
Sent from my Sony
Neophodan mi je :kezo:
