2015 Fiat Ægea/Tipo
Re: 2015 Fiat Ægea
Paketi opreme: Easy, Urban, Lounge
Motori:
1.4 95 KS Fire, 6 manual, 127 nm, 5.7 l/100km
1.6 110 KS Etorq, 6 auto, 152 nm, 6.4 l/100km
1.3 95 KS Mjt, 5 manual, 200 nm, 3.7 l/100km
1.6 120 KS Mjt, 6 manual, 320 nm, 4.2 l/100km
1.6 120 KS Mjt, 6 auto, 320 nm, 3.9 l/100km
Motori:
Re: 2015 Fiat Ægea
Bilo bi, ali se plašim da će cenovno konkurisati Oktaviji.Risto napisao:Turska drzava je delom finansirala razvoj ovog auta, ako se ne varam, veliki iskorak u odnosu na Lineu. Bilo bi lepo kada bi bio cenovno konkurentan Rapidu.
- iggyboy
- Postovi: 1134
- Pridružio se: 16 Jul 2012, 14:31
- Garaža: 407 coupe 2.2 petrol
- Lokacija: pozarevac
Re: 2015 Fiat Ægea
ako su dimenzije sa turskog sajta tacne onda je iste sirine kao oktavija a duzine kao rapid i ima malo manji gepek od rapida
▒▓██ P █ A █ R █ T █ I █ Z █ A █ N ██▓▒
Re: 2015 Fiat Ægea
Re: 2015 Fiat Ægea
Nekako mi unutrašnjost deluje socijalno.
Re: 2015 Fiat Ægea
Pa ako je u rangu Peugeota 301 ili Rapida, onda je i očekivano.
Re: 2015 Fiat Ægea
Re: 2015 Fiat Ægea
Početak.
https://www.youtube.com/watch?v=7ohzfNtBA70
Re: 2015 Fiat Ægea
80 kg lakša on Linee.
Re: 2015 Fiat Ægea
U Turskoj Aegea, u ostatku sveta - Tipo.
Galerija - http://www.quattroruote.it/gallery/2015 ... 2015_.html
https://www.youtube.com/watch?feature=p ... RCxqzbBy_o
The new Fiat Tipo is a compact notchback four and a half meters long, 178 cm wide and 148 cm high. The wheelbase of 2 meters and 64 centimeters, the seats were five and the capacity of the luggage up to 510 liters. It 'was designed from the outset as a sedan, but it is possible that on the same platform can be made station wagon and hatchback variants, much in vogue in the markets of Central Europe.
Engines
To equip the new Fiat Tipo will be two Multijet II turbodiesel and two petrol engines, with manual or automatic transmission, and a power range between 95 and 120 hp. These are the first information from the FCA, which will reveal the other technical specifications of the new type in the coming weeks along with the prices, which should be quite affordable because the Fiat Tipo aims openly at customers attentive to the real value of a car.
Produced in Turkey
The Fiat Tipo was designed in Italy by the Centro Stile FCA and developed in Turkey with Tofaş R & D. Turkish will be produced at the plant in Bursa, where Fiat currently also produces models Linea, Qubo, new Doblò, Fiorino and Doblò Cargo. From there it will reach the over 40 market to which it is intended. In Turkey, however, will be marketed under the name Fiat Aegea "as a tribute to a nation has always been strategic for FCA," he explained from Turin.
A name "historic"
The Fiat Tipo Fiat tradition fished from the same name that was assigned to the C segment produced in Cassino from 1988 to 1995 and in 1989 won the award for Car of the Year. Three innovations introduced by the type were the galvanized body, the tailgate and fiberglass for digital instrumentation dell'allestimento DGT which was very futuristic for its time and the segment of the type.
- trojanac
- Editor in Chief
- Postovi: 33137
- Garaža: KIA Ceed JD 1.4
Re: 2015 Fiat Ægea
Ko zna sta jos spremaju italijani.
Po meni će ovaj tipo biti odličan za naše tržište samo ako ne preteraju sa cenom.
- Day Walker
- Postovi: 23581
- Garaža: BMW X3
Re: 2015 Fiat Ægea
Skroz kulturica. Ako ne preteraju sa cenom, bice dobra kupovina.
- starac vujadin
- Postovi: 11477
Re: 2015 Fiat Ægea
Za službena kola i rent a car...konkurencija za Škodu Rapid.
Re: 2015 Fiat Ægea
Hatch je za Evropu. Ovo je za sirotinju s' juga.
