Biciklizam
Postovi: 4659
Re: Biciklizam
paja napisao:
Ji 4Tze napisao:kako ti ne otpadnu mošnice od ovog sedišta (položaj pre svega)?
OO nikad nisu ugrožena na biciklu ako imaš uske gaće, bile one bici ili ne. Na sedištima stradaju guzne kosti tj tkivo oko njih i koren ponosa jer je tu glavni oslonac.
Nisu @pajo, cak se moze reci da im prija pritisak :mrgreen:
The graphic below is a thermogram which compares sitting in a chair vs. sitting on a bike seat. When you are sitting in a chair, the pressure is distributed across the meaty part of your bum. But when you are on a traditional bicycle seat, you are leaning forward and almost all of the pressure is on the base of your penis or vulva, with none of the pressure being shared by the broader back part of your butt (red indicates maximum pressure).
Not only do traditional bike saddles crimp the artery that supplies most of the oxygen to the penis, but they also compress the nerves against the pelvic bone for a possible double whammy.
As for the newer seats with cutouts, they appear to make matters even worse, given that they focus the pressure on an even smaller area.
Re: Biciklizam
http://www.ceradure.com/cycling/products.php?sub=59
10-ofazna drumska kaseta 84g. :trljamoci: Potpuna bolest.
Postovi: 4659
Re: Biciklizam
Gde izvlacis ove stvari?
Ja sam svoju pakovao od 2.
Bila 11-19 :mrgreen: a onda sam shvatio da sam preterao pa sam turio 11-21
Sve u svemu, minijatura u poredjenju sa tvoja Penzija kasetom
Re: Biciklizam
Bez ovoga se ne pojavljuj na proleće. :kezo:
Sent using Tapatalk
Re: Biciklizam
@ MM Vrni mi onih 2 x 50 € pa puta 4 i kupujem kasetu.
@ Zuzazu Negde ovde nalazim http://weightweenies.starbike.com/forum/
Moja penzionerska kaseta se vrti, a tvoja? :isplazijezik: :kezo:
Re: Biciklizam
Pajo, jel ti i drzac WC papira od karbona? Samo jos L-a da pocnes da cuniras :mrgreen:
Ja sam danas opet pocepao gumu. Sada spoljasnju. Lep dan, previse jurcanja i divljanja i ode :mrgreen:
Razmisljao sam da kupim neke do jaja gume, al sam onda skontao da zadnju menjam bar 2x u sezoni... Bacanje para :mrgreen:
Re: Biciklizam
NexT napisao:Pajo, jel ti i drzac WC papira od karbona?
Nije. Još uvek. :kezo:
Koje gume kupuješ i kako ih to cepaš? I dalje skačeš biciklom sa zidova?
Re: Biciklizam
Ma neam pojma, pogledacu sutra kako se zovu. Sreca, pocepao kod garaze, pa ga samo spustio dole.
Pa cepam tako sto retko normalno vozim, i zadnja kocnica je idealno nastelovana da blokira tocak. Svako skretanje, kocenje, zavrsi blokiranim zadnjim tockom i kontrolisanim proklizavanjem. SKoro kao WRC :mrgreen:
Re: Biciklizam
I šta ja sad da ti kažem? Samo noastavi tako. Kupuj najjeftinije gume jer za bolje nisi. :D
BAJKER
Postovi: 6086
Re: Biciklizam
Post od BAJKER »
Kako ne znas Pajo, Next radi policajku svaki put kada treba da stane :)
Re: Biciklizam
Jasno je to meni. Al' kad je tako ne može da očekuje da mu gume traju.
Re: Biciklizam
paja napisao:@ MM Vrni mi onih 2 x 50 € pa puta 4 i kupujem kasetu.
Eve ti...
:kezo:
Re: Biciklizam
:kezo:
Šaljem ih Urketu da ih ubaci na karticu.
BAJKER
Postovi: 6086
Re: Biciklizam
Post od BAJKER »
Cuveni drifter na bajku. Evo Pajo kada savladas sa svojim Hi Tech bajkom ovo javi se coveku, on to radi sa sve metalnom korpom na prednjem tocku.
http://www.youtube.com/watch?v=R5AZ8yYHNts
Re: Biciklizam
Za drift je Pony s kontrom dušu dao.
