Mobilne telekomunikacije
Postovi: 9320
Re: Mobilne telekomunikacije
Ako prati san onda mora i puls da prati 0-24, na osnovu toga i radi.
Edit: na sajtu www.dcrainmaker.com sam video najbolje testove fitnes satova. Zanimljiv članak o merenju pulsa, i kako je primetio da kad mu poraste puls "u mirovanju" da je to nagoveštaj bolesti ili preumora:
For me, the most valuable use case of the data is around fatigue and predicting some sickness. For example, my resting HR is usually in the 39-42bpm range. When that rises, I know that my training load, travel load, or work load may be getting out of balance. That might be expected for a heavy training week. But if I’m on an easy training week and my resting HR has been climbing to 50bpm, then something might be amiss. It may be other stresses, or other factors. But it’s a key indicator that something isn’t right.
Historically I’ve found that as soon as my RHR breaks about 51-52bpm, I’m sick and/or feeling beat down/exhausted. I may be lacking sleep or just overwhelmed. For each person, how you respond to that will vary. And what those values are will vary as well. But most people that track RHR data do find fascinating patterns in it.
Poslednja izmena od grujicd u 06 Dec 2018, 10:31, izmenjeno 1 put ukupno.
Stalno prati i puls, ali mu to ne srče bateriju. Tj, konstantno merenje pulsa ulazi u tih 10+ dana trajanja baterije. Možda bi bez tog merenja trajala mesec dana :)
Postovi: 28267
Huawei je solidan activity tracker, ali kao smart watch je ispod proseka.
S obzirom da se baterije na satovima brzo pune(ispod 2 sata na bezicnom punjacu za Galaxy watch), nema razloga da ne ponude ekran koji stalno sija, pogotovo sa trajanjem baterije kao na Huawei gtu.
Nema dodatnih aplikacija, ne moze da se razgovara preko sata, nema loudspeaker i mikrofon, ne moze da se cita i salje poruka, samo primaju notifikacije, nema google ili nelog drugog assistanta, nije bas brz, ima lag...poprilicno ogranicen uredjaj, ali realno, skroz srazmerno svojoj ceni.
Ko hoce bas smart watch, ima dosta boljih opcija, ali i skupljih naravno.
Khm, khm :) Slika
Postovi: 22168
Ovakav sat treba da nosiš par meseci, godina, onda vidiš šta ti eventualno nedostaje, a šta ne koristiš. Plašim se da veliki deo mogućnosti satova pretrpanih opcijama ostane neiskorišćeno od strane korisnika, a neke bitne stvari ostanu nedorečene - najpre ekran koji nema stalan prikaz i baterija.
Neproduktivno je napinjati se u objašnjenjima kako nešto nije dobro za nekog drugog jer prosto ne možeš biti u tuđim cipelama.
Postao sam kao Laki, ne valja :mrgreen:
More Bad News From Apple As iPhone XR Price Slashed
https://www.forbes.com/sites/ewanspence ... -sale/amp/
Adding to the signs that the newest iPhones are not meeting Apple’s internal sales targets, let alone the lofty ambitions of significantly increasing the annual sales of the iOS-powered smartphones, details of the actions taken by Tim Cook’s team to boost sales have come to light.
Postovi: 28267
Vladapetr napisao:Khm, khm :) Slika
Haha Slika
klisko
Postovi: 666
Post od klisko »
Postoji i honor 4 band, nije smart watch ali koga zanima fitness tracker mislim da je vrlo dobra opcija. Ima 24 sata praćenje pulsa, kvalitet sna itd, a izdvaja ga mogućnost praćenja plivanja. Bolestan sam pa ne mogu da probam plivanje, a samo zato sam ga kupio. Nemam živaca da ga nosim noću (probao jednu noć samo), a danju nosim mehaničke satove.
Postovi: 21228
Ima na telefonu aplikaciju za puls?
klisko
Postovi: 666
Post od klisko »
Aplikacija je ista ova koju je Vlada kačio, Huawei health. I meni daje takav ekran sa podacima o snu.
Ovako izgleda HR (skinuo sam band ujutro, pa je zato prekid)Slika
Postovi: 21228
OK, hvala. Dakle, nema problem da snima 24h dnevno puls?
Samsung Gear S3 i Galaxy Watch ne mogu, mogu da prate samo u mirovanju. Plus Galaxy Watch ima neki problem sa senzorima, ne radi kako treba HRM.
Spa-Francorchamps
Postovi: 635
Post od Spa-Francorchamps »
Ima Galaxy Watch opciju kontinuiranog merenja pulsa. Ima tri opcije: kontinuirano, na svakih 10 minuta i nikad (ručno).
Postovi: 21228
OK, nisam dovoljno istražio. Kažu da ima problem sa merenjem svakako.
@klisko Huawei Band 3 vs Band 4, ima li nešto bitno osim ekrana?
Izvinjavam se modovima, ovo je više za onu fitness temu.
Spa-Francorchamps
Postovi: 635
GW je verovatno najslabiji kao fitness tracker, što se ostalih funkcija tiče je odličan sat.
Što se tiče pomoći vozačima, odlično radi kao hands-free uređaj, a radi i standalone navigacija, tj. ne treba mu telefon da bi navigacija radila. Koristi Here WeGo aplikaciju i mape.
Za navigaciju kad je povezan sa telefonom može da se koristi i posebna aplikacija koja je besplatna za sat, ali se za telefon plaća oko 2.5 EUR. Koristi Google Maps. Na satu je grafički prikaz "sledećeg poteza", ima glasovno navođenje i sat blagovremeno vibrira da opomene pre skretanja ili neke promene.
Inače, ne znam da li i jedan drugi sat, osim Samsunga, nudi daljinsku konekciju sa telefonom: ako su oba na Internetu, sa istim samsung ID-jem(ulogovan isti korisnik na oba), notifikacije sa telefona stižu na sat i kad telefon nije u blizini. Zaboravite telefon kod kuće, a notifikacije stižu na sat.
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
Podržava li poruke i pozive ili samo vidiš da te je neko zvao?
