Vesti iz auto-industrije
Postovi: 49375
Re: Vesti iz domaće i svetske auto-industrije
Nakon Saab-a i Volkswagen razvija motore sa varijabilnom kompresijom.
Volkswagen Group readies revolutionary new petrol engine tech
http://www.autocar.co.uk/car-news/indus ... ngine-tech
New technology including coasting and variable compression ratios to lead a surge in petrol engine efficiency for the VW Group
The VW Group is planning to use new technology, including variable compression ratios, to boost its petrol engine efficiency
The Volkswagen Group is preparing a revolution in petrol engine efficiency, according to hints from Audi technical chief Ulrich Hackenberg.
Speaking at Audi’s recent annual conference, he said engines with “electro-mechanical assistance for forced induction” and “variable compression ratios” were in development.
Hackenberg also said coasting would become an important fuel-saving technology over the next few years. A coasting function - where the transmission disengages from the engine on the overrun - is already built into some VW Group models equipped with dual-clutch automatic gearboxes.
Hackenberg gave no details on how Audi will introduce variable compression ratio technology, but the principle has long been something of a Holy Grail for engine designers. Being able to vary an engine’s compression ratio depending on the immediate demands being placed on it should lead to significant advances in efficiency.
In 2000, Saab demonstrated its experimental supercharged and turbocharged SVC engine, which used a tilting block to change the volume of the combustion chamber and, therefore, the compression ratio. More recent designs have altered compression ratios by changing the throw of the crankshaft or through the manipulation of conrods.
Audi demonstrated electrically assisted forced-induction technology in the summer of 2012 as part of an experimental twin-turbo V6 engine. It used an electrically driven turbo which was spun up to high speed by a motor and used to force air into the engine at low speeds — something a normal turbo cannot do until the engine is running at higher revs.
This technology not only allows turbocharged engines to perform effectively from a standstill, but is also very effective for downsized two and three-cylinder engines.
Hackenberg said coasting technology - which has significant fuel-saving potential - would arrive in four stages. The first level already features on some dual-clutch ’boxes, with the next version expected to function when the car is travelling below 4mph. The ultimate version will see the transmission decoupling and the engine shutting down when cruising at speed, travelling downhill or approaching traffic lights that are about to turn red.
Electric turbochargers, variable compression ratios, cylinder deactivation and coasting combined have the potential to hugely improve the real-world economy of future petrol engines.
Postovi: 49375
2015 Chevrolet Cruze
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Post od perfiko »
Bolje da nisu ništa dirali.
dragan
Postovi: 9349
Post od dragan »
ovo kao fokusov ruzniji brat...
Postovi: 15334
Sreca pa ne dolazi u evropu. :D
Sent from my ALCATEL ONE TOUCH IDOL using Tapatalk
Postovi: 49375
Land Rover Discovery slavi 25 godina postojanja.
Postovi: 49375
Postovi: 33126
HONDINA 5-GODIŠNJA GARANCIJA
Honda Srbija obaveštava svoje klijente da, počevši od 23. marta 2014. godine, imaju mogućnost produženja garancije svojih vozila za još 12 ili 24 meseca i to bez ograničenja kilometraže. Mogućnost produženja će imati klijenti čija se vozila još uvek nalaze u okviru fabričke garancije (3 godine ili 100.000km).
Prilikom potpisivanja ugovora o produženoj garanciji, klijent će dobiti i brošuru u kojoj su detaljno opisane sve pojedinosti Hondine 5-godišnje garancije, kao i navedene sve neophodne informacije o vozilu i klijentu. U slučaju eventualne promene vlasništva nad vozilom, garanciju je moguće preneti na novog vlasnika.
Doplata za 12 meseci produžene garancije iznosi 300eur, dok doplata za 24 meseca iznosi 500eur. Celokupan iznos je neophodno uplatiti u dinarskoj protivvrednosti, po srednjem kursu NBS na dan potpisivanja ugovora. Produžena garancija počinje da važi prestankom važenja fabričke garancije (3 godine ili 100.000km).
Za sve dodatne informacije možete kontaktirati +381 (0)11 20 10 928, 20 10 984 ili 20 10 952.
Izvor: Honda Srbija
Postovi: 49375
2014 Datsun on-DO
Postovi: 49375
Đekna...
kvcali
Postovi: 3007
Garaža: Omega B2 2.0
Lokacija: Kraljevo
Post od kvcali »
sta je ovo , nemacke table, a desni volan
Postovi: 23580
Nova Corsa tj restilizacija.
Ako dobro brojim, ovo je 4. verzija. :nemampojma:
Postovi: 23580
3. Verzija, s tim da ovoj menjaju unutrasnjost i opet nesto spolja cackaju.
Nesto slicno Golfu :kezo:
Послато са GT-I9300 уз помоћ Тапатока
Dusan
Postovi: 4285
Lokacija: Wien
Post od Dusan »
:ccc:
