Alternativni pogoni, sistemi i komponente
Re: Alternativni pogoni, sistemi i komponente
Xepoj87 napisao:
Laki021 napisao:Lepo neko rece na forumu, vreme za elektricna kola ce biti kad BMW pocne masovno da ih proizvodi. I tacno ce tako i biti...
Nisam ni znao da i Bmw razvija svoje baterije, poput Tesle i Mercedesa, mislio sam da koriste tudje.
Tesla ima Panasonic baterije, koje doduse pravi po licenci.
Postovi: 28268
To je vec komplikovano, zajedno razvijaju, a Panasonic najvise radi na samim celijama, koje sam razvija.
Ali nisam znao da i Bmw razvija svoje i da ce za 3 godine presisati Tesline i Panasonicove.
Postovi: 49375
Sprema se struja za neke modele.
Пунтилак
Postovi: 228
Pridružio se: 16 Jan 2018, 16:16
Lokacija: favela Beograd
Post od Пунтилак »
Hm, koja li je šansa da Puntać dočeka "uradi sam" elektrifikaciju ? :)
Možda će to na kraju biti neki sistem prepravke svih standardnih vozila? Ne znam samo kako će klimu da prikače i koliko li to posrče ba(k)teriju ?
Stavi se klima od Priusa.
Postovi: 49375
Postovi: 49375
Postovi: 49375
ABB powers e-mobility with launch of first 350 kW high power car charger
http://new.abb.com/news/detail/4439/abb ... ar-charger
Pioneering technology leader ABB launches new Terra HP High Power fast charger at Hannover Messe, extending global reach.
With the number of electric vehicles on the road rising, the global demand for powerful and energy efficient vehicle charging stations is ever increasing. At Hannover Messe, ABB launched its newest EV charging solution, the Terra HP, the first 350 kW product on the market. Charging time for a range of 200 km is just eight minutes.
Ideally suited for use at highway rest stops and petrol stations, Terra HP’s ultra-high current has the capacity to charge both 400 V and 800 V cars at full power.
The addition of Dynamic DC power sharing technology, allows a two-power cabinet charging system to charge a couple of EVs simultaneously, with up to 350 kW, while dynamically optimizing the available grid connection and the power delivery to the two vehicles.
Commenting on the launch Frank Muehlon, Head of ABB’s Global Business for Electric Vehicle Charging, said: “We are committed to supporting the expansion of electric vehicle charging systems across the globe to drive cleaner environments. Creating innovative state-of-the-art and energy efficient solutions which are scalable to expand and flex with our customers’ needs is at the heart of ABB’s philosophy.”
Additional power cabinets and charge posts can be added after installation, delivering a cost-effective and future-proof solution for expandable charge points that can grow as the EV base grows.
To further improve performance, Terra HP delivers the highest uptime due to redundancy on power and communication, and individually cooled charging cables. Having proven its paces in numerous commercial electric bus field installations, the power cabinet is also extremely reliable.
For charging operators, Terra HP provides the additional benefit of ABB Ability™ Connected Services, which deliver enhanced functionality, including the ability to easily connect chargers to back offices, payment platforms or smart grids systems. More importantly, remote diagnostics, repair and over-the-air software updates, minimize downtime and keep running costs low.
Terra HP delivers a number of additional benefits for consumers, including an intuitive, easy to use touchscreen display and multiple payment options.
ABB has provided charging solutions as part of its drive to promote sustainable mobility since 2010 and has sold more than 6,500 cloud connected DC fast-chargers around the world for passenger cars and commercial vehicles.
Postovi: 49375
Orbis Wheels, a startup from Mill Valley in California, tries to re-invent the wheel once more and promises a breakthrough in electric drive.
https://insideevs.com/new-ring-drive-in ... akthrough/
The Orbis Ring Drive Wheel is kind of an in-wheel motor, but different from hub motors and, according to company founder Marcus Hays, it saves weight, cost and complexity. Having such wheels apparently improves performance, efficiency and braking (outside disc and caliper operates 20% cooler), too.
Here is the idea:
Orbis Ring Drive Wheel (source: HondaPro Jason)
“The company’s brochure explains “the technology divides a wheel or cog into two essential parts, a stationary hub and a rim or ‘ring.’ The ring rotates about the stationary hub, driven by a lightweight, high-speed motor.”
Hays says the ring drive is more efficient while reducing vehicle weight as much as 40% and driveline complexity by 75% compared to powertrains in which the electric motors (in-hub or in the driveline) power an axle.”
Orbis Wheels presented prototypes in scooters and in a Honda Civic Type R Hybrid, which was equipped with two Orbis Ring Drive Wheels.
Each wheel is rated at 70hp (50 kW) – 140 hp total. The weight of the wheel is 16 kg (35 lbs), while a traditional hub motor would be 31 kg.
Soon, the company will test and demonstrate the Orbis Ring Drive Wheel and will be looking for commercialization in the automotive industry or maybe military.
The World’s 1st Honda Civic Type R Hybrid with AWD. Orbis has engineered 2 electric wheel motors that add a total of 140 hp to the rear wheels of the new 10th generation Honda Civic Type R. Added benefits include, better handling, more power, better MPG, more even weight ratio, cooler brake temps, faster 0-60 times & more. I will be testing this new system out on my own 2017 Civic Type R very soon. Please Subscribe to watch the upcoming videos and info about this ground breaking new tech.
Postovi: 7905
Ovo ja pricam da treba napraviti vec 30 god :) od kada smo na fakutetu radili elekricne automobile - oblik i dimenzije tocka su idealne za integraciju sa elektricnom masinom (generator / motor - inace svi pogresno nazivaju elektricni motor :)). Jedino je uvek bio onaj stari problem, prljavstina - vlaga, prasina, inercija i sitnice :)
@ljuba
Su počeli sa električnim gradskim busevima u Holandiji? Trebalo bi da se menjaju I stanice, iznad koje stoji punjač I dok bus stoji, puni se automatski.
Tek sad vidim kako sam glupo sastavio rečenicu :glavomuzid:
Poslednja izmena od passenger u 30 Maj 2018, 09:04, izmenjeno 1 put ukupno.
Postovi: 7905
Bas juce dolazim iz Beograda na Schiphool i gledam kako se pune:) Drugar mi je inace poceo da izradjuje pantografe, a nekada je bila i moja profesija pa me malo interesuje :) Inace za kretanje kroz selo i gusto naseljenu oblast idealni su, posto se skoro ne cuju ni kada krecu, ni kada koce - sto je kod nasih buseva inace ogroman problem - buka. Inace u BG je stvarno katastrofa, svaki drugi autobus izbacije naftu na sve strane...
Inace kod mene na poslu - u selu busevi su i hidrogenski..
Poslednja izmena od ljuba u 30 Maj 2018, 09:07, izmenjeno 1 put ukupno.
E baš to. Firma za koju radim ih sklapa. Mislim da su taj sistem I patentirali.
Postovi: 25248
