Mercedes E facelift
Postovi: 23580
Re: Mercedes E facelift
Pa to prkosi zakonu... Mecka iznad zakona! :mrgreen:
nuk
Postovi: 7607
Garaža: Renault Espace 2.0dCi
Lokacija: Ns
Post od nuk »
@DW
moze biti mada mi je i dalje cudno da nema prskalica
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Post od Laki021 »
Tako je, necemo dozvoliti da cvrsti materijalni dokazi stanu na put nasim ubedjenjima :)
Mora imati prskalice!!! :)
Postovi: 23580
npr UK:
By the law in UK Xenon lights can be fitted if headlights are with self leveling and washer system installed :)
Scuderia napisao:Mozda jednostavno nema prskalice.
ma ima sigurno :mrgreen:
moimoi
Postovi: 210
Pridružio se: 26 Apr 2012, 14:14
Post od moimoi »
Koliko sam ja shvatio, standard je:
Dnevna - LED
Kratka - LED
Duga - Halogena
Doplata:
Full LED
Pa onda nema ni razloga za prskalice.
Re: AW: Mercedes E facelift
Malopre pored mene na parkingu E63 AMG FL. Izgleda odlicno ali meni je duplo jeftiniji CLS atraktivniji :pardon:
Gesendet von meinem GT-N7000 mit Tapatalk 2
Ali taj CLS nije 63 AMG :djavo:
Koliko se secam, kod facelift E klase nema Xenona, standardno idu halogena a uz doplatu ide LED. I istina je da LED farovi nemaju prskalice, nema ni novi S:
Halogen
LED
Poslednja izmena od HKS u 11 Apr 2013, 23:29, izmenjeno 1 put ukupno.
methane.master napisao:Ali taj CLS nije 63 AMG :djavo:
Nema veze...zadovoljio bih se sa 350 CDI :D
Postovi: 25221
Laki021 napisao:Tako je, necemo dozvoliti da cvrsti materijalni dokazi stanu na put nasim ubedjenjima :)
Evo, evo:
E-Class facelift has no headlight washers?
by Markus Jordan | December 17, 2012
Ever notice that the facelifted E-Class has no built-in headlight washers, which were previously used with Xenons? We asked Mercedes-Benz - and received corresponding information.
According to the makers, the omission of a headlight cleaning system is not due to the "2000 lumens limit". Above this value currently for xenon lights automatic headlamp leveling and headlight washers are required. For LED headlamps this does not apply.
The headlight washers serve to reduce glare for oncoming traffic caused by dirt. "Recent studies show that the effect of the headlamp cleaning system has both positive and negative effects on the glare. So that the use of a headlamp cleaning system for the purposes of road safety is questionable," according to a spokesperson for Mercedes-Benz.
"The elimination of the headlamp cleaning system also represents a weight saving, with a full tank of up to 6 kg. Thus a CO2 saving of about 0.5 g/km is achieved. Therefore, we have decided in terms of sustainable environmental and economic vehicle operation to delete the headlight washer system."
Regardless, MB also saves on the cost of production, and fewer parts have to be stocked - which also may be one of the main reasons for the omission of the headlight washers. This option will no longer be available with the facelift of the E-Class (W212 sedan / S212 wagon / C207 coupe / A207 cabriolet).
http://blog.mercedes-benz-passion.com
Scuderia
Postovi: 13495
Post od Scuderia »
E sto bi voleo da vidim vlasnika E FLa kako objasnjava nasem panduru zbog cega nema prskalice :rofl: LED? Jel se to maze na leba?
nuk
Postovi: 7607
Lokacija: Ns
Post od nuk »
sto, dovoljno je da odstampa ovaj tekst I lupi neki pecat :)
Sent from my BlackBerry using Tapatalk
Floyd napisao:
Pravi si gastos. Da ima "nišan" i da je dizla. :kezo:
Ja bi AMG-a pa nek ide život. Ionako bih celu godinu štedeo za registraciju i jedan rezerovar, al bih onda napravio džumbus i narednih 12 meseci čekao da mi vrate dozvolu. Taman da opet uštedim za registraciju i gorivo i onda opet u krug. :kezo: Uostalom prelazio bih isto ko i sad. :kezo:
Jel može E63 da se uzme sa zadnjim spojlerom u boji auta a ne onim odvratnim karbonskim?
Scuderia
Postovi: 13495
Post od Scuderia »
