Čuo sam da prave 5kom dnevno i da ne planiraju preko 2000kom da ih naprave, tako da verovatno već uveliko spremaju naslednika.
Lamborghini Huracan
- Uroš S.
- Postovi: 11029
- Lokacija: BGD
Re: Lamborghini Cabrera
Jel ovo Aventadorov naslednik?
- Postovi: 24939
- Garaža: Fiat Stilo 1.9 MJ
- Lokacija: NS
Ovo ce biti Gallardov naslednik. Aventadora je vec napravljeno 2000 i vise, a njihova je prica da ce limitirati proizvodnju na 4000 komada u sta iskreno sumnjam. Taj model ce biti aktuelan oko 10 godina, prema tome sumnjam da ce biti nekih cuda da ne dostignu 4000 ili da ce da naprave naslednika mnogo ranije.
AutocarLamborghini is set to continue its 50th anniversary celebrations with the unveiling of a new concept car at the Frankfurt motor show in September that closely previews its upcoming Gallardo replacement, sources close to the Italian supercar maker have revealed.
The new two-seater, the production version of which is set to go on sale in the UK during the second half of next year, follows the example of its predecessor in sharing key components, including a lightweight carbonfibre and aluminium spaceframe structure, with the replacement for today’s Audi R8, due in 2015.
The new car, which carries the internal codename LP724, is said to have grown marginally in length to almost 4500mm, or 16mm longer than its predecessor, with width and height remaining close to the 1900mm and 1165mm respectively of the Gallardo.
Together with an edgy new exterior, the Gallardo replacement is set to adopt a new interior layout that, with a slight increase in wheelbase over its predecessor at 2600mm, will offer added levels of accommodation.
Despite harbouring initial plans to base its new car around a contemporary carbonfibre monocoque similar to that of the Aventador, Lamborghini has been forced to follow a more conservative route dictated by parent company Audi and its second-generation R8 supercar.
Both cars have been conceived around a modular spacefame. This will allow them to share vital components, including selected parts of a new, lightweight carbonfibre and aluminium structure that, Autocar can confirm, weighs 198kg in the form to be used by the Audi. That is 24kg less than the all-aluminium structure used by the current R8.
Despite using a similar structure, the R8 and the Gallardo replacement will receive different wheelbases. The Audi’s is 30mm longer than the Lamborghini’s for greater levels of interior accommodation, including stowage space behind the seats. By using a shorter wheelbase than the Audi, the structure of the new Lamborghini is a further 3kg lighter, at just 195kg.
The new spaceframe structure will be clothed in a body that uses a combination of carbonfibre-reinforced plastic and aluminium panels. The move is aimed at bringing the new mid-engined Lamborghini to the scales at less than 1500kg — the official kerb weight of today’s four-wheel-drive Gallardo.
Power will come from an updated version of the Gallardo’s naturally aspirated 5.2-litre V10 petrol engine. It will be tuned to deliver close to 600bhp and 400lb ft of torque in standard guise, while complying with stringent new EU6 emissions regulations set to come into force next year.
The reworked engine will be mated to a standard six-speed manual gearbox, while the new seven-speed dual-clutch automatic from the R8 will be optional, replacing the current Gallardo’s six-speed automated manual ’box.
Alongside standard four-wheel-drive models, Lamborghini also plans selected rear-wheel-drive versions of its new supercar.
Meanwhile, rumours suggest that the Gallardo replacement will take the name Cabrera. In keeping with Lamborghini tradition, it refers to a line of Spanish bulls whose lineage can be traced to other famous breeds, including the Miura, Gallardo, Navarra, Veragua and Vistahermosa-Parladé.
- Postovi: 24939
- Lokacija: NS
Sve sumnjam da ce manuelac uopste biti u ponudi.
- Postovi: 24939
- Lokacija: NS
- Postovi: 24939
- Lokacija: NS
- Postovi: 24939
- Lokacija: NS
- Postovi: 24939
- Lokacija: NS
Vuce na Sesto Elemento, ocekivano.
- Postovi: 24939
- Lokacija: NS
- Postovi: 24939
- Lokacija: NS
