2020 Toyota Yaris
Postovi: 21186
Re: 2020 Toyota Yaris
Meni liče na one sa CH-R, a koji su kao obrnuti sa Civica IX FL.
Postovi: 9284
Nespretno mi izgleda prelaz na drugu boju krova. Na prvu loptu mi bolje izgleda jednobojni model, što ne bi očekivao. Videćemo uživo.
Postovi: 33027
Ove godine navala noviteta u B segmentu. Stigli novi Clio, 208/Corsa, Yaris...
Biće zanimljiva tržišna utakmica.
Postovi: 13879
To je u Evropi uvek bilo popularno.
Postovi: 49310
Postovi: 49310
Postovi: 49310
Toyota GR Yaris
Powering the GR Yaris is the 1.6-litre turbocharged three-cylinder that produces 261 PS (257 hp / 192 kW) and 360 Nm (266 lb-ft) of torque, with the Japanese version being a little punchier, with 272 PS (268 hp / 200 kW) and 370 Nm (273 lb-ft).
The engine is paired to a six-speed manual transmission and four-wheel drive, and can be enhanced with the two Torsen limited-slip differentials available in the Circuit Pack. The latter adds performance-tuned suspension and 18-inch forged wheels, wrapped in 225/40 Michelin Pilot Sport 4s tires.
The car has three driving modes, Normal, Sport and Track, which split the torque between the front and rear axles by 60:40, 30:70 and 50:50, respectively. In each mode, the balance will automatically adjust depending on the road conditions, vehicle behavior and driver inputs. Thus, it can direct up to 100 percent of the torque to the front or rear axle at certain times, improving grip and allowing for faster cornering.
With a curb weight of 1,280 kg (2,822 lbs) and a power-to-weight ratio of 4.9 kg per 1 PS, the GR Yaris does the 0-100 km/h (0-62 mph) sprint in less than 5.5 seconds and maxes out at an electronically governed 230 km/h (143 mph).
Postovi: 12567
Opak auto!
Postovi: 10134
Zver. Pravi mild WRC na putu. To dugo nismo imali. Deluje da ce se brzo rasprodati nevezano za cenu. Verovatno biti i dobra investicija.
dunx81
Postovi: 5745
Garaža: Civic 1.8
Lokacija: Zrenjanin
Post od dunx81 »
Dobra zamena za TS.
t
Postovi: 10052
opako izgleda u ovoj varijanti, mada ni stock mi nije losa
Postovi: 49310
Postovi: 49310
Evropska verzija.
Postovi: 49310
Postovi: 49310
Osnovna verzija.
