Koenigsegg Regera
Scuderia
Postovi: 13495
Re: Koenigsegg Regera
Post od Scuderia »
Ovo leti :D
Postovi: 9932
Moze li neko da pojasni na koju foru radi ta transmisija?
Ovako kako je napisano teško je zaključiti. Biće sigurno detalja tokom salona.
Inače volim grofove automobile. Hrabar je i spreman na inovacije. :thumbup:
Sent using Tapatalk
Postovi: 49212
https://www.youtube.com/watch?v=m61GQd_rOwA
Then there's the drivetrain: Koenigsegg's proven 5.0-litre twin-turbo V8 sits proudly in the middle, pumping out a healthy 1100bhp alone, direct to the rear wheels.
But instead of being attached to a normal transmission, the Regera uses something called the Koenigsegg Direct Drive system. There's a small, crank-mounted electric motor to fill the torque gap (and act as a starter motor) together with a hydraulic coupling.
Each rear wheel then gets its own electric motor, and we're told that triplet of electric motors amounts to around 700bhp alone. Christian tells us that from take-off, with the coupling open, you power off purely on electric drive, with no need for a gearbox. As soon as it gains a few more revs, the hydraulic coupling begins to close, and the smaller crank-mounted electric motor joins in to help the bottom part of the torque curve.
http://www.topgear.com/uk/car-news/koen ... 2015-03-03
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
pornic od auta, odusevljen sam :o
1500ks, ovo stvarno prevazilazi ocekivanja... bas me interesuje, sada kada su usporili F1, koliko su sporiji najbrzi automobili od F1 bolida...
sigurno da je f1 i dalje brza dosta, gume, menjac, tezina itd.
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
starac vujadin
Postovi: 11473
Post od starac vujadin »
Ovo će da ide kao trolejbus :)
Ovaj covek je Bog.
Dzoni_m
Postovi: 2000
Garaža: BMW 118i, CX-60
Lokacija: DE
Post od Dzoni_m »
Interesantan podatak: hibridni deo (baterije, kontroler, motore itd) je radio Rimac. Svaka cast. Decko je poceo celu pricu o EV iz cistog entuzijazma, pratio sam temu kada je tek razmisljao sta da radi sa E30 i prvim igrarijama na HR BMW forumu. Doduse imao je i sredstava (ne uzlazim u pricu odakle i kako, iako je to sve poznato) da sve to lepo upakuje, angazuje prave ljude i dobije jako dobre proizvode (ne mislim samo na auto, koji je vise show i tehnoloski demonstrator)
Scuderia
Postovi: 13495
Post od Scuderia »
stefanan napisao:http://jalopnik.com/how-the-1-500-hp-ko ... 1689181377
Mene izgled ne oduševljava...
Mene ni izgled ni sam Koenigsegg kao firma, nikad nisam voleo takva auta, ali performanse su ludilo.
Dzoni_m napisao:Interesantan podatak: hibridni deo (baterije, kontroler, motore itd) je radio Rimac. Svaka cast. Decko je poceo celu pricu o EV iz cistog entuzijazma, pratio sam temu kada je tek razmisljao sta da radi sa E30 i prvim igrarijama na HR BMW forumu. Doduse imao je i sredstava (ne uzlazim u pricu odakle i kako, iako je to sve poznato) da sve to lepo upakuje, angazuje prave ljude i dobije jako dobre proizvode (ne mislim samo na auto, koji je vise show i tehnoloski demonstrator)
+1 Totalni rispekt za dečka.
AcaKayak
Postovi: 4865
Post od AcaKayak »
Risto napisao:pornic od auta, odusevljen sam :o
Sporiji su toliko da bi smešno izgledalo kad bi izašli na stazu. Bilo koji automobil bi izgledao kao da voziš autić na sudaranje.
Scuderia napisao: Mene ni izgled ni sam Koenigsegg kao firma, nikad nisam voleo takva auta, ali performanse su ludilo.
Kako to mislis firma te ne odusevljava?
Naprave suplje karbonske tockove i to je sranje, a Audi napravi Rotor i to je ekstra? :kezo:
Scuderia
Postovi: 13495
Post od Scuderia »
Nisam rekao da je sranje nego da ne volim takve automobile. Slicno je i sa Paganijem.
Otkud rotor u prici? :zbunjen:
Rakhil
Postovi: 8341
Post od Rakhil »
Christian Erland Harald von Koenigsegg je presao zivot na najtezem nivou i otkljucao sve cheatove, sad se prosto zajebava i pravi sta hoce. Dizajnerski nisam odusevljen njegovim kolima, ali sve ostalo je divine level i mogu samo da mu se divim do imbecilnosti.
A, da, cisto trola radi, Rotor gowno :kezo:
