Odlaganje štedljivih sijalica i elektronskog otpada
Postovi: 15985
Re: Odlaganje štedljivih sijalica i elektronskog otpada
nuk
Postovi: 7607
Garaža: Renault Espace 2.0dCi
Lokacija: Ns
Post od nuk »
Ovo su ubodne koje se koriste na lampama i ukrasnim "spot" svetlima
Sent from my SK17i using Xparent Blue Tapatalk 2
Postovi: 12579
Slomljena stedljiva sijalica
Malopre mi se to desilo u spavacoj sobi.
Po onome sto sam procitao na netu, ispade da sam komtaminirao sobu i usisivac, i tepih za sva vremena.
Ako je istina ono sto ameri pisu, te sijalice su tesko njesra...
Sent from my Amiga 500, using Kickstart 1.2
Postovi: 15985
Re: Slomljena stedljiva sijalica
Moja je juce pregorela. Odnosno, kada je dosla struja (nestajalo je na kratko) samo je pocela da smrdi. Potamnela je pri dnu, ali nije pukla.
Postovi: 12579
http://www2.epa.gov/cfl/cleaning-broken-cfl
Ja sam kasno ovo sve procitao, ali nije lose da se zna...
Before Cleanup
Have people and pets leave the room.
Air out the room for 5-10 minutes by opening a window or door to the outdoor environment.
Shut off the central forced air heating/air-conditioning system, if you have one.
Collect materials needed to clean up broken bulb:
stiff paper or cardboard;
sticky tape;
damp paper towels or disposable wet wipes (for hard surfaces); and
a glass jar with a metal lid or a sealable plastic bag.
During Cleanup
DO NOT VACUUM. Vacuuming is not recommended unless broken glass remains after all other cleanup steps have been taken. Vacuuming could spread mercury-containing powder or mercury vapor.
Be thorough in collecting broken glass and visible powder. Scoop up glass fragments and powder using stiff paper or cardboard. Use sticky tape, such as duct tape, to pick up any remaining small glass fragments and powder. Place the used tape in the glass jar or plastic bag. See the detailed cleanup instructions for more information, and for differences in cleaning up hard surfaces versus carpeting or rugs.
Place cleanup materials in a sealable container.
After Cleanup
Promptly place all bulb debris and cleanup materials, including vacuum cleaner bags, outdoors in a trash container or protected area until materials can be disposed of. Avoid leaving any bulb fragments or cleanup materials indoors.
Next, check with your local government about disposal requirements in your area, because some localities require fluorescent bulbs (broken or unbroken) be taken to a local recycling center. If there is no such requirement in your area, you can dispose of the materials with your household trash.
If practical, continue to air out the room where the bulb was broken and leave the heating/air conditioning system shut off for several hours.
Actions you can take to prevent broken compact fluorescent light bulbs
Information from other sources relating to the accidental breakage of CFLs
Top of page
Why is it important to clean up a broken CFL properly?
CFLs and other fluorescent light bulbs contain a small amount of mercury sealed within the glass tubing. When a fluorescent bulb breaks in your home, some of this mercury is released as mercury vapor. To minimize exposure to mercury vapor, EPA recommends that residents follow the cleanup and disposal steps described on this page.
Top of page
What if I can't follow all the recommended steps? or I cleaned up a CFL but didn't do it properly?
Don't be alarmed; these steps are only precautions that reflect best practices for cleaning up a broken CFL. Keep in mind that CFLs contain a very small amount of mercury -- less than 1/100th of the amount in a mercury thermometer.
However, if you are concerned about your health after cleaning up a broken CFL, consult your local poison control center. You can reach your local poison control center anywhere in the U.S. by calling 1-800-222-1222. You can call your poison control center any time you have questions or in an emergency. You can also consult your physician about potential health effects from mercury exposures.
nuk
Postovi: 7607
Lokacija: Ns
Post od nuk »
Koliko sam se ja zive nagutao, trebao sam da mrem bar pe-ses' puta.
Sent from my Nexus 7 using Tapatalk HD
dragan
Postovi: 9347
Post od dragan »
e bas to... malo je to povece proseravanje...
Bax jesi li zao vatrogasce? :kezo:
Ta vrsta sijalica, fluo,neonke, kako ko vec zove, se koriste decenijama i nisam cuo da je neko imao problem.
Dovoljno je provetriti, i naravno pokupiti staklene komadice upravo usisivacem.Oprati ruke nakon toga.
Ovo napisano je u stilu, ne stavljajte macku u ves masinu...
Naravno treba biti razumno oprezan.
Postovi: 22148
I u retrovizoru je slika onog što je nazad iako je retrovizor napred. Amerima sve mora da se napišeš, da je vatra vruća, a led hladan, inače ne bi znali. Namazali bi slomljenu sijalicu na 'leba da im ne napišu da treba da se baci u smeće.
Tapatalk HD
Ne treba da im pišeš jer su glupi nego da ne bi tužili :)
Postovi: 15985
Tacno. Cak su i pametni, jer traze rupe u tim uputstvima, kako bi uspeli da izvuku koji dinar/dolar.
Sada verovatno armija njih mozga koju zivotinju da ubace u mikrotalasnu na susenje, a da nije macka ili neka od stotina drugih zivotinja koje mogu da stanu, a nisu navedene kao zabranjene za tu rabotu :kezo:
