VW Golf VII
dragan
Postovi: 9344
Re: VW Golf VII
Post od dragan »
sa jedne strane dobar rezultat, mada na ovoj listi ima malo razlike u vremenima, a sa druge strane, megan 2 rs je skoro sekund brzi, kao i astra opc, a megan 3 rs je druga liga.
mada mi je krajnje sumnjivo kako je obican megan 2 sport skoro sekund i po brzi od njegovog derivata r26 koji je jaci, ostriji i najbitnije ima lsd...
mada, dok dodje najbrza verzija golfa, bice to jako brz auto...
Dusan
Postovi: 4285
Lokacija: Wien
Re: VW Golf VII
Post od Dusan »
Zanimljiv rezultat, ako se uzme u obzir da golf ima 30ks manje.
Inace R iz gezinog posta nije render, evo i teksta.
After months of eagerly waiting, Volkswagen has finally revealed the 2015 Volkswagen Golf R and it’s certainly been worth the wait! Featuring a host of visual and engine updates compared to the previous-generation Volkswagen Golf R, the new car promises to redefine the high-powered, hot hatch market.
Starting straight with the engine, the 2015 Volkswagen Golf R features an advanced turbocharged 2.0-liter four-cylinder engine helping to produce an impressive 300PS from 5,500 to 6,200rpm. Maximum torque is now 380Nm, an increase of 30Nm over the previous generation Golf R. These figures become even more impressive when you consider that the Volkswagen GTI delivers just under 230hp, and that’s already an extremely potent hot hatch.
Compared to the Volkswagen GTI, the 2015 Volkswagen Golf R’s engine features a new cylinder head, exhaust valves, valve seats and springs, pistons, high-pressure injection valves as well as a redesigned turbocharger. All that power is then sent through a permanent 4MOTION all-wheel drive system which has always been a trait of the Golf R. Completing the powertrain is a 6-speed manual transmission featuring a reinforced clutch and short-travel shifting. The 2015 Volkswagen Golf R can also be purchased with a 6-speed dual-clutch DSG gearbox.
The 2015 Volkswagen Golf R then features a new sports suspension setup individually tuned to the new car. Compared to the regular Golf, the new Golf R sits 20mm lower, thus making it a further 5mm lower compared to the GTI. Helping to deliver optimal handling in the new Volkswagen Golf R is a MacPherson-type front spring strut with a newly developed low wishbone and track-stabilising scrub radius.
From a steering perspective, the 2015 Volkswagen Golf R is equipped with the same progressive steering system as the recently updated Golf GTI. This system reduces the required turning radius of the Golf R dramatically from 2.75 turns for full steering down to 2.1 turns.
Helping to bring the 2015 Volkswagen Golf R to a stop are new internally ventilated discs and black brake calipers complete with the’R’ logo at all four corners. The front brake pistons measure 60mm in diameter, with 42mm diameter ones used in the rear.
As all previous Golf R’s, the new car also features dramatic new styling. This comes in the form of new bumpers, side sills, rear diffuser, chrome dual tailpipes and a new layout design of the bi-xenon headlights. The 2015 Volkswagen Golf R then comes fitted with 18-inch wheels as standard and can be optioned with 19-inch alloy wheels.
The 2015 Volkswagen Golf R can be optioned in eight different body colors. They consist of Lapis Blue Metallic, Pure White, Tornado Red, Night Blue, Limestone Grey Metallic, Reflex Silver Metallic, Deep Black Pearl Effect and Oryx White.
The 2015 Volkswagen Golf R will make its public debut at next month’s IAA Frankfurt Motor Show 2013. European deliveries will begin in end-2013 into early 2014, the Chinese introduction will take place in the summer of 2014 and the U.S. deliveries start late 2014. German prices will start at 38,325 euros.
Re: VW Golf VII
Rezultat je odlican jer je citav sekund brzi od 6ice ED 35 a "samo" 0.6s sporiji od R modela.
Od Focusa ST je slabiji 20ks ali je brzi na pravcu.
http://www.sportauto.de/vergleichstest/ ... tml?show=4
Sve u svemu, jako dobar auto :doubleup:
Postovi: 14350
Re: VW Golf VII
Ne svidja mi se izduv na r-u.
Postovi: 10128
Re: VW Golf VII
Meni se eR u kompletu ne svidja, ako bude ovakav kao sa slika...
Tapatalk Post
Re: AW: VW Golf VII
ftj napisao:Ne svidja mi se izduv na r-u.
:plusone:
4 izduva je previse za hatch C segmenta.
Gesendet von meinem GT-I9505
Dusan
Postovi: 4285
Lokacija: Wien
Re: VW Golf VII
Post od Dusan »
Slazem se, zato sam i mislio da je render neki.
dragan
Postovi: 9344
Re: VW Golf VII
Post od dragan »
zanimljivo je da je po testovima gti brzi od performance pack, i da je verzija i jednog i drugog sa dsg-om sporija od manuelca...wtf?
http://www.zeperfs.com/en/match4563-4623-4572-4601.htm
inace, slazem se, dobar auto, platforma da se zavrsi nekom jacom verzijom...
Re: VW Golf VII
dragan
Postovi: 9344
Re: VW Golf VII
Post od dragan »
au koliko duze brzine kod dsg-a, pogotovo 5. i 6. nije ni cudo toliko manja potrosnja...
do sada mislim da nikad nije bila ovakva situacija sa manuelni vs dsg...ili da nagovorimo mareta i ftj-a da to provere :kezo:
Postovi: 10128
Re: VW Golf VII
Kadgod :) Probali i japancerosi...
https://www.youtube.com/watch?v=X4HpD5K ... ata_player
Tapatalk Post
Postovi: 14350
Re: VW Golf VII
Piše da su lansirali sa 3,200 obrtaja što je možda previše tj. sigurno da je bilo proklizavanja.
Milos
Postovi: 9296
Garaža: tedeijevi geteijevi
Re: VW Golf VII
Post od Milos »
To je fabricki launch na mk6 R.
Postovi: 14350
Re: VW Golf VII
Za r je ok jer ima 4x4, al pricam za gtia.
Milos
Postovi: 9296
Re: VW Golf VII
Post od Milos »
Ja mislim da je isti launch i na GTI.
