Vazduhoplovi
Postovi: 4967
Re: Vazduhoplovi
Hvala! :thumbup: Čuo sam za ovu firmu iz Ajdovščine (sela u Sloveniji, blizu tromeđe sa Italijom i Austrijom, nekada poznatnog po fabrici sokova Fructal). Pošto je Geza napisao da su tihi, bilo je jasno da je reč o nekim ultra-lakim avionima. Ali nisam očekivao Pipistrel. :)
Postovi: 4656
Re: Vazduhoplovi
@snork :pivo:
Geza napisao: 31 Mar 2023, 00:09 Retko viđam civilne avione da lete u ovoj formaciji.
Letelo se i tako. Ne secam se da li sam ja fotkao ili je mene fotkao drugar:
Negde iznad Banata.
Postovi: 4656
Re: Vazduhoplovi
171 planes will land every day from Russia to Turkey
Türkiye is preparing to receive 171 aircraft from Russia every day as of June. Izvestiya newspaper, which is known for its closeness to the government in Russia, which has not lost its interest in Turkey despite the Ukraine war, wrote that as of June, the Russian Aviation Agency decided to increase the number of flights to Turkey by 50 percent.
According to the news, there will be 1,200 weekly flights from Russia to Turkey in the summer. According to the planning, 10 airline companies in Russia will operate 750 flights, and Turkish Airlines will operate the remaining 450 flights.
The most direct flights to Turkey are planned to be made to Istanbul, Antalya, Bodrum, Dalaman and Izmir. Ilker Özkan, the Turkish tourism representative in Russia, who gave information to the Izvestiya newspaper about Turkey's expectation of Russian tourists this year, said, "We expect the decline that started in 2019 with the COVID-19 epidemic to be completely overcome this year and that more than 6 million Russian tourists will visit Turkey."
Alavi Turci su toliko podigli cene hotela, da je najgore šišanje na delu.
Postovi: 49211
Re: Vazduhoplovi
Postovi: 7474
Re: Vazduhoplovi
Terasa za posmatranje. Fina varijanta za ubiti vreme.
Postovi: 49211
Re: Vazduhoplovi
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
Post od Harvey Specter »
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
YU-ANI, B733, ponovo u vazduhu. Izgleda da je doslo krajnje vreme da se ubaci prava masina u saobracaj :)
Postovi: 5294
Re: Vazduhoplovi
Ne. Ide u Kinu.
Postovi: 4656
Re: Vazduhoplovi
Er Srbijin Bus 319 APK posle poletanja iz IST imao problema sa presurizcijom.
Pise na Airport Haber:
https://www.airporthaber.com/havacilik- ... dondu.html
Al' ne pise na T6. Mudri Perica cuti. Da se ne zameri.
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
zuzazu napisao: 20 Apr 2023, 11:00 Er Srbijin Bus 319 APK posle poletanja iz IST imao problema sa presurizcijom.
Pa on i komentare odmah brise, a kamoli da citave vesti objavljuje. Koliko vidim avion se posle vratio za BEG na FL260. Ja sam mislio da tek ispod FL200 moze da se dise normalno.
cozmo napisao: 14 Apr 2023, 15:24Ne. Ide u Kinu.
Znam znam, salio sam se. Zna li se kada odlazi
Postovi: 4656
Re: Vazduhoplovi
Zavisi sta je bilo sa presurizacijom.
2 packa drze visinu kabine, svaki sa vazduhom sa kompresora jednog od motora.
Ako je razlog pack, moze da poleti sa takvim kvarom, ali je limitiran na FL250 (bar sto se tice Boinga).
Putnici bez maske mogu do FL140 a posada do FL100.
U Er Srbiji je raspad sistema, pruzili su se vise nego sto su dugacki.
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
Imaju dosta aviona na neplaniranim radovima, neki kasne sa radova, tako da je prilično haos u redu letenja, pa nije ni čudno koliko aviona uzimaju u wet leasing. Mada se meni čini da je veći problem u broju posada
Postovi: 4656
Re: Vazduhoplovi
Ozbiljne firme uzmu u obzir svaki check koji mora da se uradi, zna se koliko traje C, koliko D check, i naprave plan po tome.
Neki avion mora da ostane i u rezervi ako se ne zeli doci u situaciju da se vet-lizuju avioni.
Ovde se ETF i jos kojekoji koje uzimaju u lease ubise od para. Da ne pominjem da li je usluga koju pruzaju u standardima Er Srbije.
Sigurno je i nedostatak posada uzrok, ali ko im je kriv. Konkurisali su nasi momci koji rade u Turkisu i nikoga nisu primili, jer primaju clanove partije bez jednog sata naleta.
Vecina koja je dostigla uslov za penziju (51 god. zivota) ce da pokupi istu i zapali negde napolje.
A oni samo neka nastave ovako.
Ako citas zamaero, ima tu OK komentatora ali je Scuric veca budala od Petra.
Postovi: 4656
Re: Vazduhoplovi
http://direktno.rs/vesti/drustvo-i-ekon ... ograd.html
A danas je Šustikla prebacila 800 putnika (!!!) za IST na Turkish.
Ne znaju kako da ih spakuju.
Raspad stize pre sezone.
