Postovi: 11337
http://www.kupujemprodajem.com/Italijan ... d=27789753
fq400
Postovi: 1458
Garaža: Lancer
Post od fq400 »
Evo, da se malo osveži tema
Nije loš krem, ali je meni previše sladak, odnosno nema 'dovoljno' čokolade/kakaa. Nešto između Eurokrema i Nutele. Nutela je definitivno bolja, sa Lino ladom i da ne poredim. Svejedno, nije loše, poješće se :D
Inače, mlečna čokolada im je baš dobra. Nije u rangu švajcarskih koje sam jeo (standardne, iz supermarketa), ali je bolja od Milke na primer.
Nema bolje kombinacije od IT nutele i panetone :)
Djole
Postovi: 640
Post od Djole »
There was talk of Nutella in the following France declares war on hazelnut cream because manufactured with palm oil, but today I found a video that I was literally shocked.
Ok I said there will be a bit 'of palm oil as you want it to be, Nutella is good I eat the same .... s useless, not there's a little '... there's a lot inside!! In this video (which is not a video complaint but only an amateur video to make people think, and gets its purpose very well) is clearly seen as palm oil is contained in a barattolone of delicious cream ...
Then the composition is milk chocolate and hazelnuts ... but what percentage?
Well the so-called main ingredients are 27% of the content, while 70% is made up of sugar and oil, 3% other ingredients such as emulsifiers, lecithin or flavorings.
Do not believe us? well watch the video demonstration you will be shocked, and you can safely repeat the experiment at home.
http://youtu.be/h99_vkuRmtc
What do you think? you still think palm oil is cheap? To you the considerations....
Mozda ima gramatickih gresaka jer je prevod sa Italijanskog.
Incognito
Postovi: 611
Pridružio se: 01 Apr 2012, 22:06
Post od Incognito »
Nutela je nezdrava, u to nema nikakve sumnje, Preslatka je i po meni izvikana. Vise volim Cipiripi - kvalitetan, ukusan plus sto vise volim da finansiram domacu privredu nego tamo neke italijane, hrvate, austrogermanske nacilende itd. Strane proizvode kupujem samo onda kada domaci ne nude odgovarajuci kvalitet za svoju cenu, a to bar sa kremovima nije slucaj. :)
Cipiripi beše pravi Centroproizvod? ;)
Sent using Tapatalk
Texonja
Postovi: 4510
Garaža: X3
Lokacija: Poker table
Post od Texonja »
@Incognito, sad si se ... :ccc:
nuk
Postovi: 7607
Garaža: Renault Espace 2.0dCi
Lokacija: Ns
Post od nuk »
Jasta nego pros'ro, da prostite :)
Nego, juce sam probao cipiripi tablu, ili kako da nazovem vec, prvi put od kada ih je Nestle preuzeo (citaj: domaca a jaka) i mogu reci da sam prijatno iznenadjen, ukus ni priblizan nekadasnjem Cipiripi- ju koji mi nikada nije lezao, bas mi se svidelo. Ako je i krem takav, mislim da bi mu trebalo dati sansu :)
Incognito
Postovi: 611
Post od Incognito »
Texonja napisao:@Incognito, sad si se ... :ccc:
Mislis na moj stav o Nuteli ili na pricu o Cipiripiju ? :)
Znam ja da je Nestle kupio Centroproizvod, ali bez obzira na to sto je svajcarski kapital usao u domacu firmu (citaj nakon sto je privatizovana) to je sa stanovista koristi za domacu ekonomiju i dalje na neki nacin domaca firma jer se njeni proizvode proizvode ovde (ovde se i plasiraju), zaposljava domace radnike i konacno porast vrednosti kompanije od prodaje Cipiripija jaca srpsku privredu, a ne svajcarsku - Nestle kao kompanija uzima samo profit od prodaje. Zato kupujem Cipripi jer ne vidim ozbiljnu razliku izmedju njega i nekih stranih kremova niti po pitanju kvaliteta, niti u ceni. Kad budem primetio razliku u ceni i kvalitetu izmedju Cipiripija i Eurokrema s jedne i Linolade, Nutele ili nekog drugog stranog krema s druge strane, onda cu preci na nesto drugo. Ali mi nikako ne idu u glavu ljudi koji u startu diskvalifikuju sprske proizvode ma kakvi oni bili dajuci uvek prednost stranim. Znam na desetine ljudi koji uvek radije kupuju Linoladu ili hrvatsku "Domacicu" makar bile trostruko skuplje od nekog domaceg proizvoda.
nuk napisao:Jasta nego pros'ro, da prostite :)
Bravo, ispao si mnogo pametan sa ovakvim komentarom, nema sta. ;) Idi sad i pocasti sebe necim u to ime. :)
nuk
Postovi: 7607
Lokacija: Ns
Post od nuk »
Obavljeno sinoc :)
Sto se ljutis odmah, patriotska propaganda sa poluinformacijama stvarno glupo deluje u ovakvoj temi.
Sent from my Lumia
Texonja
Postovi: 4510
Garaža: X3
Post od Texonja »
@Incognito, ti ne vidis razliku, ali ima ljudi koji vide, jer pricamo o necemu sto je stvar licnog ukusa pa se ne moze egzaktno reci "Nutella je bolja od Cipiripija", niti moze obrnuto. Moze se analizirati sa neke tehnoloske strane i sa strane sastava, ali i dalje je nekome lepse jedno, nekome drugo i bzvz je osudjivati ga sto to kupuje. Ja podrzavam stav "kupujmo domace", cak i kada je domaci proizvod za nijansu losiji, ali mora postojati granica. Sigurno da je hrvatska domacica drugacija od nase kopije i ako necije nepce oseti tu razliku, neka kupi sta mu je bolje. Pa nismo valjda toliki fanatici da jedemo losije stvari zbog ubedjenja?
Iskreno, ja kod tog keksa ne vidim razliku, jer mi je skoro svaki isti, ali zato kod krema... :kezo:
Konkretno, uvek cu kupiti Smoki pre nego strani flips, jer mi se vise svidja. Da je Smoki strani, kupovao bih opet njega. Isto vazi i za negazirane sokove. Nema boljeg soka na svetu od Nexta i Nectara. Bukvalno na svetu!
S druge strane, Jaffa domaca i ona Milkina su mi slicne, svaka dobra na svoj nacin. Nisam lud za njima, ali volim obe i tu kupim Jaffu uvek jer je nasa i jer je nekako tradicionalno. Treci primer je nasuprot prva dva - krem. Uvek cu kupiti pre Linoladu ili Nutellu nego Eurokrem ili neki drugi domaci, jer mi je za klasu ispred. Mogu da budu domaci sto puta, sto se mene tice dzabe im...
Postovi: 33160
Jaffa domaća je meni duplo bolja od Milkine, koja je prejaka.
Incognito
Postovi: 611
Post od Incognito »
@Nuk
Ne znam kakve sam to poluinformacije iznosio, ali dobro ...
Texonja napisao:@Incognito, ti ne vidis razliku, ali ima ljudi koji vide, jer pricamo o necemu sto je stvar licnog ukusa pa se ne moze egzaktno reci "Nutella je bolja od Cipiripija", niti moze obrnuto. Moze se analizirati sa neke tehnoloske strane i sa strane sastava, ali i dalje je nekome lepse jedno, nekome drugo i bzvz je osudjivati ga sto to kupuje. Ja podrzavam stav "kupujmo domace", cak i kada je domaci proizvod za nijansu losiji, ali mora postojati granica. Sigurno da je hrvatska domacica drugacija od nase kopije i ako necije nepce oseti tu razliku, neka kupi sta mu je bolje. Pa nismo valjda toliki fanatici da jedemo losije stvari zbog ubedjenja?
Ne radi se o ubedjenju, i ja volim uvek da kupujem ono sto je kvalitetnije ukoliko ima istu cenu bez obzira da li je to domaci ili strani proizvod, to nije sporno. Ali znam iz iskustva da (ne prigovaram nista tebi licno i slazem se sa tvojim stavom, stavise) ogroman broj nasih ljudi bukvalno uvek daje prednost bilo cemu stranom bez obzira i na cenu i na kvalitet. Takve stvari mi strasno smetaju, inace nemam nista protiv bilo cijeg ukusa i prava da kupi ono sto mu odgovara. Nedavno sam gledao promociju Dorininih cokolada u jednom domacem supermarketu oko cijeg se info pulta okupila ogromna masa kao da se nesto deli dzabe u najmanju ruku. Na drugoj strani gledam Swisslion-ov pult koji je bukvalno prazan. Iskren da budem, trudim se da u jednoj od sto korpi vidim bar neki srpski prozivod poput Najlepsih zelja, domacu napolitanku ili nesto slicno i nekako imam utisak da sami bojkotujemo domace proizvode. Opet kazem, ne ocekujem da svi kupujemo samo domace (niti je to moguce, niti tako treba da bude) ali bar malo vise solidarnosti i ekonomskog patriotizma u onoj meri gde to mozemo da istaknemo bilo bi nam od velike koristi umesto sto se utrkujemo da posto posto uzmemo samo ono sto je tudje.
Slazem se za Nectar sokove - ne zelim da budem pristrasan, ali od toliko sokova koje sam probao, nisam pronasao jos ni jedan priblizno kvalitetan sok kao bilo koji iz njihovog asortimana. Za njih ne bih zalio da dam ni 300 din za 1 litar. Isto vazi i za Jafu koja predstavlja inovativni brend (nesto poput Ferrerovog Rafaela ili Rocher-a recimo). Vidim da je Swisslion pokusao da je iskopira, ali nije uspeo ni 5% u tome. :)
Neskica
Postovi: 424
Garaža: Ford Focus 1.6 TDCi
Lokacija: New Woodgood
Post od Neskica »
Imaš Nectar-ovih sokova i za 300 dinara - Unique linija (valda sam dobro napisao) :D
Postovi: 4968
Texonja napisao:cak i kada je domaci proizvod za nijansu losiji, ali mora postojati granica. Sigurno da je hrvatska domacica drugacija od nase kopije i ako necije nepce oseti tu razliku, neka kupi sta mu je bolje. Pa nismo valjda toliki fanatici da jedemo
Khm... zar nije naša "Domaćica" original, proizvodi je Banini, još od vremena SFRJ?
Texonja napisao: Da je Smoki strani, kupovao bih opet njega. Isto vazi i za negazirane sokove. Nema boljeg soka na svetu od Nexta i Nectara. Bukvalno na svetu!
Slažem se! Inače, ne znam da li ste primetili da Budimka - (Užička) Požega ponovo radi! Sokovi su fantastični, bukvalno čisto voće, bez ikakvih dodataka! Čak sam poredio bistri od jabuke sa najskupljim Nektarom/Fructalom i Next Premiumom - i bolji je i od njih! Ambalaža i logo isti kao i ranije. A cena smešna, nešto tipa 70 din litar.
trojanac napisao:Jaffa domaća je meni duplo bolja od Milkine, koja je prejaka.
I sa ovim se slažem. Milka je relativno skoro iskopirala taj proizvod, ima raznih ukusa, ali je očajan i pun hemije. Ostavite otvoreno pakovanje par dana, a keks i dalje izgleda svež => hemija na delu. Naša (tj. britanska, po licenci) Jaffa je zakon!
Incognito napisao:Takve stvari mi strasno smetaju, inace nemam nista protiv bilo cijeg ukusa i prava da kupi ono sto mu odgovara. Nedavno sam gledao promociju Dorininih cokolada u jednom domacem supermarketu oko cijeg se info pulta okupila ogromna masa kao da se nesto deli dzabe u najmanju ruku. Na drugoj strani gledam Swisslion-ov pult koji je bukvalno prazan. Iskren da budem,
A najtužnije je što "Kraš" više uopšte nije tako dobar kao u vreme Jugoslavije. Proizvodi su im sada skupi, a srednjeg kvaliteta. Ako baš moram da kupim nešto hrvatsko, pre bih izabrao rum-pločice koje pravi Kandit - Osijek, ili Mondi čokoladice koje pravi Zvečevo - (Slavonska) Požega. Ali ni ova dva proizvoda mi više nisu tako ukusna kao u vreme SFRJ (ili sam možda ja bio mali, pa se ne sećam :) ). Inače, Pionir - Subotica ima mnogo bolje proizvode u ovom segmentu. A i Soko Štark isto.
Što se tiče kremova, "Cipiripi" je dobar, ali je meni "Eurocrem" još bolji. "Krem-krem" je takođe odličan. "Linoladu" bih kupovao, bez obzira što nije domaća, ako bi se prodavala normalna verzija. Ovu sa 3% lešnika "za Srbe, Bosance i Šiptare" neću. Vređa me takav odnos prema kupcima.
Poslednja izmena od snork u 14 Nov 2013, 08:21, izmenjeno 2 puta ukupno.
